The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
giantkiller
Quote from: sparkman on November 04, 2006, 09:37:38 AM
I saw this on another site posted by someone called "VORTEX"
Couldn't sleep, up early nursing a cold (due to overwork and obsession with this project) sitting in front of the woodstove and hoping our days of having to stoke these black monsters soon be at end,  the thought ocurred to me: Perhaps I'm thinking  about this device all wrong. So here goes wild ass theory #2.
The coils are wound in a bifilar manner for two reasons
# 1 reason is to set up a low level plasma glow between the windings. (see JLN labs info on plasma glow) This will generate all kinds of hash and frequencies exciting the windings, similar to white noise (the worst case scenario) and it will be uniformly distributed between the windings. The latest photo clarifications of the two tier open device seem to show a familiar sight. (thanks guys for the photo clarification)  A high voltage spark coil or ignition coil (to the left rear) and a toroidal transformer ( to the right rear) The large SM17 device black box looks a lot like the electrostatic HV supply pulled from a copy machine or laser printer.
#2 The coils act as tuned transmission lines that select from the hash the two frequencies for resonance. They can then be tuned (act as radio reciever). to create the difference of two high frequencies to create Schuman Resonance . They must be trimmed to exact length to produce the difference frequency. Since they are bifilar, temperature effects and capacitive loading should act the same on both and keep the difference frequency relatively stable.
A capacitor creates the 90 degree phase shift between groups of coils  and with the inclusion of a magnet the ionic  field is set rotating in a preferred direction. This creates a rotating ionic VORTEX  (excuse me)
Ions from the ionosphere are pulled down by the rotating vortex to augment the effect. (similar to the long thin funnel from a tornado)
So two frequencies are not being generated, merely selected (like a radio reciever) from the "worst case scenario", the plasma hash generated by the electrostatic field between windings. The overall device acts as a macro-electron (as above, so below) so it may be possible to create macro electron structures that in a fractal sense act as their smaller counterparts. Tune too closely and you'll probably ionize a column of air that will bring a discharge (lightning) on your device if it doesnt vaporize before that (hence the required detuning). The device only needs a tiny battery to get the plasma going (driving the ignition coil as a HV step up ). How the DC output is derived is yet to be theorized. This is just a start in a different direction, to be tested. Perhaps bits and pieces of this theory were presented in the long thread at Overunity. To the many contributors thanks is given. SM says it is a conversion device (ions to electrons). A device for tapping the charge in the ionosphere.
The plasma is not the source of the power it is a means to an end. It is the millions of little lightning strikes in the plasma (kicks?) uniformly distributed along the transmission line that excite the tuned circuits to concrescence. An ionic rotation is what will couple to other ions nearby by vortex motion and draw down more power into the device. Of course the static plasma glow can do nothing in itself. When in rotation the ions are the means to couple to the ionosphere. The earths magnetic field will help to act on the funnel to augment the compact horizontal spin of the ionized air column. Nature always uses spin structures to couple energy between potential gradients, e.g hurricanes. Haven't you always wondered how a long thin funnel cloud maintains it's shape for long periods of time. The point is, ions are everywhere, but mostly concentrated in the ionosphere. They are influenced by magnetic fields and this is possibly the reason for the rotating magnetic field. As more energy in the form of ions is drawn into the rotating ionic field, more plasma is created and it will be converted into energy in the form of real electrons by resonant absorption in the coils. The process feeds itself.
Yes! Because on higher power levels the ion flow looks just the production of waves in the metal detector post.
Thank you for this post.
Just augmenting here to bring together relevancy:
This explanation, with the metal detector explanation, with the previous picture posts of the harmonic freak waves, with the overlay post by marco on top of my pic of the device sitting on the Earth plane with the avi about the mag fields of the 4 segment coil. Tight, really tight!
--giantkiller.
c0mster
Update from the lab: All 4 posts now cut and routered into top and bottom paltes. Next update after bottom ring coils are wrapped. btw I took this outside and if you put your hands between the plates you can feel heat.
Comster
giantkiller
Quote from: ctglabs on November 04, 2006, 12:54:44 PM
Quote from: giantkiller on November 04, 2006, 12:29:31 PM
Let's drop the creation of kicks issue and move on.
And we wonder why Mannix and SM left us to it?  SM has told us the SECRET LIES IN THE KICK.
??? THE SECRET LIES IN THE KICK!  SMs OWN WORDS!  WHY ARE WE LOOKING FOR OTHER THINGS TO EXPLAIN THE TPU?
PLEASE SOMEONE EXPLAIN?
Dave.
This is not an eflame!
Yes. The kicks are the heart of it. We are looking at the power and the mag fields from the kicks. Because the production of the waves via the configuration setup is what reactes with the environment, known and unknown. You can watch the wheels spin all day, but the rest of us are planning a trip. No offense intended.
We aren't on the porch anymore...
--giantkiller. We need your knowledge for the next leg.
allcanadian
Hello Giantkiller
You and I may have missed the most obvious point not mentioned here. A few post ealier mikestocks 2006 reposted some statements from SM, and something seemed odd? SM makes reference to tesla's magnetometer experiments in paragraph two, why? If you read it carefully there is one statement that says" his(tesla)research found that you could tune the magnetometers to certain specific frequencies and tap directly into large magnetic waves.When I say large, I am referring to HUGE.that was useable power."
This device will never work until you hit the correct frequency that is a given, what is it? Tesla tuned his magnetometers to pick up lightning storms-not the earths magnetic field, the earths magnetic field is constant and cannot be harnessed--unless lightning which is hitting the ground continually somewhere on earth all of the time, lightning having millions of amps, resonates the earths magnetic field. There are systems now which can tell exactly where lightning hits by monitoring a small frequency band and vectoring to show the location .The weather service shows these results-every lightning hit in a defined area(north america), so what would happen if you tuned SM's machine to this frequency and multiples of that frequency? I have yet to find the exact frequency they monitor but am googling it. I think ctglabs may have had it right when he said why are we running off in every direction when SM basically spells out how to do this if you read his document and pay attention. Maybe we need to go to square one and analyse every paragraph step by step, it seems everyone, including myself has predetermined how this works in there judgement,and it seems to be going nowhere? Maybe if any one is interested we could start a new thread and analyse this as I said paragraph by paragraph, input given only on the topic at hand. These are my thoughts anyways.
allcanadian
Bingo!
LDAR lightning detection ranging used in northamerica is at 66Mhz, but I don't think this is it. Here is a better option World Zues-long range lightning detection system detects radio noise from lightning at VLF frequencies 7-15 Khz from thousands of Km away. So really this deivice could be triggered by lightning hitting anywhere in north america? how many lightning strikes hit in north america per second, I would think a lot. If 7-15 Khz is the magic number that would be too cool.
