The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
raburgeson
Well 2 tickle circuits and a row of zeners to drop the access and SM was wrong , internally I had the coil wrapped correctly, it's just that I had all the taps coming out in the center instead of the outside. My results have been poor to none so far. I get some voltage but no power. Drops to 2 volts as soon as it gets a 12 volt load, doesn't matter whether I pipe it through and inductor first or not. It may be that I have to many wraps in the collector cores (8 of them). Got a pic from the scope on the other puter , toss it up soon. It looks great till you put a load to it. It would be a waste to spout frequencies to you it was suposed to turn out 4" ID and 6" od like the one in the video, and it's out of whack, it's about 7" OD. I'll keep working. Probably going to have to rewrap it. The only thing I can say is I left almost and inch between coil sections. I thought that was way to much, but, maybe not. By the way that's a great idea let's start a new post and analyse this mess post by post.
giantkiller
Okay,
If you break a bar magnet then each magnet's field reconnects. When you put a toroid in Earth's flux plane and turn it on you are essentially submitting a magnetic bubble into the flux field, no? And the Earth's flux lines are deflected or broken, no? And as the broken lines connect elsewhere there is energy. Now let's power down the toroid and the field collapses. The previously disconnected flux lines will not have interference and will return to the normal state. This breaking, connecting, and realigning back to normal creates a spherical magnetic wiping action in space. Lets put a wire / collector / antennae there at 90d and harness that action. I think SM coils are doing that.
In my first graphic, if shows the unpowered toroid. The blue lines represent the flux lines.
The 2nd graphic shows the powered toroid. The smaller arrows represent the flux flow across the collector.
The arrow through the center represents the path for the vortex or ionic flow previously mentioned by Vortex, Marco, Sparkman.
This only shows the first cycle.
The next step: the Twilight zone...
--giantkiller.
allcanadian
supersam I believe ctglabs comments were meant for me,rehashing old news. I still do not get this though, so you have broken the earths field lines requiring x watts input, the control field is collapsed, field lines return cutting load lines, but the conservation of energy still applies here. Control input x is equal to earth field y, x=y there is no getting around that,so there is something else missing. I have problems swallowing frequency hash as well, tesla was no amature, he mastered resonance like no one else has, I think there is a missing time function here, the earth field couples to the collapsing control field so you get both back, if the working magnetic field has to circle the device like a spinning wheel then a perfectly conservative control pulse on one side of the disk opposing the earth field could turn and couple with the earth field. But then what,and why two disks, Im just not getting this.
gn0stik
Quote from: tao on November 03, 2006, 06:01:33 PM
What if,  just saying what if, the current that is flowing through the collector wires is eddy currents themselves? Is that possible? Could the kicks themselves be eddy currents and this is why steven couldnt solve the heat issues, because if the currents are eddies then he couldnt have the free energy without the generation of heat in the copper collectors.  Just an idea...
giantkiller
We all make one brain. No man is an island.
@dave?
Your ideas and experiments were accepted. I have been both right and wrong, misunderstood. ignored, accepted, disfavored. But I didn't leave. So my ideas don't fit in with where this thread is right now. I accept that. But they will fit in where neccessary, though they are not the whole answer.
I plead to you to come back. The kicks are an integral part and an all encompassing part. We all know that. Don't just fly off the handle and fly away. The rest of us aren't ready yet to not have you here. :'( Didn't you see your value. I did and told you many times. And so did others. Which raises a question for myself. Have you put more value on the abuse than the favor and accomplishments? If a poster seems to poke fun at anybody then just blow it off. Besides, where else you gonna get this much abuse? Come on? Can't my bsh*t tirade here win you back?
Don't get feverish over an idea. Just get accomplished. If the thread takes a sidebar then just let it go by and reconnect later. I still read through the parts where I don't want to be absorbed into. The number of pages drop by half? when you deleted. If that isn't involvment then I don't know what is. I told all my concern is with the mag fields. Your concern is somewhere else. That's great. But don't let someone push you away. There is a thin line in email between heckling, sniping, comedy. I have put out comical remarks only to have them come back as sniping. But I refuse to go away. So, did this 2nd attempt at bs'ing you work?
And if others aren't jumping on the kicks bandwagon then that parade is all yours. Go for it. And your right, you mentioned it and got blown off. But the BEMF kicks are there plus something else. Lucky you.
And shame on us for not focusing on the kicks heavier. But again, others are coming into this thread from their view and need to learn the other views that are foreign to them. You are heavily focused on the right area. Come on back and party with us? Bring what ever you want. Garanteed nobody else can. They can only bring what they want.
   I learned this along time ago. I didn't get sniped at so what about you makes anybody think you're a target. I for one don't see you that way. Respect is always first. You gave me answers when I asked questions. Bring your toys back and lets get moving forward again.
--giantkiller. One for and All for one.
