The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
0 Members and 31 Guests are viewing this topic.
bob.diroto
I think I now have a theory on how the Steven Mark TPU works:
The Theory
My theory is that it's based around a rotating electrostatic field. i.e. a Field of charges. A rotating field of charges by my understanding will generate a rotating magnetic field. Obviously the faster the rotation, the stronger the magnetic field and therefore the higher the voltage and current created in the output wires. I assume there is an output coil which the rotating magnetic field passes over. Given that this high intensity magnetic field could be rotating at 6kHz (360000 rpm!) that would induce a lot of power into the output coil.
A conductor when hit with a relatively high voltage square wave I think will exhibit a 'kick' but I think there is also another way of generating a 'kick'; more on this later.  I think this kick has a large electrostatic component. As per the tesla description this 'kick' has some unique characteristics. This is also supported by the electron field generator patent of Patrick Flanagen. I believe this kick is somehow connected to the ionesphere/earth's magnetic field.
I believe as long as the electrostatic field is maintained, the ionesphere will provide all the necessary electrostatic charge. Subsequent kicks will add to the electrostatic field and thus the magnetic field. Thus the idea of a jet turbine effect or the power winding up and winding down. I've also read some articles suggesting that electrostatic charges have intertia which would also explain the wind down effect.
How to get the electrostatic field rotating ?
I'm going to assume that when a 'kick' occurs in a wire, existing electrostatic charge will be repulsed away from the position in the wire where the 'kick' occurs. If a wire is laid in a circle and you can get the kicks to occur in rotation around the wire then you have rotation of 'kicks' and therefore rotation of the electrostatic fields etc.
I think if you generate two square waves of differing frequency and apply these to either end of the wire, you will have pulses that start at slightly differing times from each end of the wire and will 'slap' together at a certain point in the wire - creating the kick. If you have a 6khz difference in the frequencies then the slap point will move along the wire at 6khz. Since the wire is laid in a circle that gives rotation at 6khz. I also think the 'head' on collision aspect might alleviate the need for a high voltage in this part of the circuit ?
The circular wire should use litz wire. Litz wire is made up of many insulated fine copper wires. Ideal for high frequency applications. Each fine wire can contribute it's own 'kick'. This wire could be tightly coiled and laid in a circle or it could be just the wire laid in a circle. Surrounding this wire would be a dielectric material which allows electrostatic charge to move. Wound as a torroid around the insulating material would be the output coil. And surround the output coil would be another layer of insulator to further keep the electrostatic field within the toroid.
Driving Circuit for the Litz Wire
You'd use some sort of timer chip to generate each square wave frequency. Don't know if 555 timer chips would be suitable. These would drive via some totem pole ? style arrangement some power mosfets rated for 2x the max frequency. You'd want some circuitry to keep two high voltage capacitors charged up. It's these capacitors that are discharged to each end of the litz wire via the mosfets. You'd also need to isolate the two mosfets. The two small toroids would do this. This circuitry would be driven by batteries. A nine volt battery could last days if the square wave voltage doesn't have to be too high.
Sizing of TPU
The diameter of the TPU is probably critical. For the earth's magnetic field/ionesphere to connect up with the TPU probably requires some sort of resonance based on geometric size. Therefore best to use the values given in the video.
Steady State
I'm assuming a steady state will be achieved when electrostatic loses equal the electrostatic input via the kicks. If not, the unit will keep increasing in power and go into melt down. In this case to avoid meltdown a feedback mechanism to reduce the voltage of the pulses would be needed. Or perhaps adjust the voltage of the input square to a voltage that does allow a steady state.
Comment Please
So there you go. A theory which I reckon is worth investigating. Any comments or observations are most appreciated.
Where I really need some help is a specific circuit diagram to drive both ends of the litz wire.
Lance
Please locate a copy of 'The free Energy Secrets of Cold Electricity' (Video tape) a technical lecture by Peter Lindemann,Dsc. (Produced by Clear Tech Inc.)
The video contains some excelent research material on Radiant Energy and describes another invention which utilizes it -The work of E.V. Gray.
(Essentially E.V.Gray used a metal screen surrounding one electrode ('solid wire') of a spark discharger to pick up the radiant 'electrostatic' component.)
rensseak
Quote from: bob.diroto on June 10, 2006, 09:18:46 PM
The Theory
Sizing of TPU
Steady State
Comment Please
Hallo bob.diroto,
nice theory. But what about when he said that his device behaves similar to a radio reveiver?
Quote from: Steven Mark
OK let us compare this story of the common radio.
Think of the power unit as a device similar to a radio receiver. No I do not want to hear
feed back informing me that I am trying to convince the world my unit works on radio waves!!!.
But it behaves very much like a simple radio receiver except for the fact that radio waves need to
be amplified before
they can be of any use to us.
My units behave as though they are variable tuning devices, and we are tuning them to a frequency just
like a radio. The closer you get to the center frequency the more power you permit the collector to
dissipate into a load.
the important difference here is that in the case of the radio, you tune into the frequency and amplify it
for use. In the case of my power unit, you create several frequencies within a space of the collector coil's
circumference. The frequencies are directly related to the circumference of the collector coil. You can begin
to collect the current and dissipate it with no need for amplification because the signal source also becomes
the feed for the power source and has the natural tendency to run with gain.  It is important that you note
that you can never tune too closely to the exact frequencies of power conversion because the power received
by the collector will instantly destroy it. We instead must deliberately tune off the frequencies of
conversion in order to make the thing properly work. Remember that it is like a furnace which feeds itself.
The hotter it gets the more fuel it gives itself to burn. that is why the control units are so very important.
Without the control unit constantly monitoring the frequencies of operation and making the necessary changes
to keep the whole thing off exact conversion frequency, then the unit would very quickly destroy it's self.
Could it be that the two rings behaves like an antenna which are at the same time send and receive? But then is still the question how it comes to the rotating magnetic field.
regards
Norbert
bob.diroto
Hi Norbert,
This turned out to be a bit of a brain dump/brain storming sessions and I've just put ideas down as they occured to me...
I take your point when Steven Mark says it acts like a radio receiver and I also think it is interesting that he said "several" which in normal use means more than 2 but not many.
Quote from Steven Mark
"In the case of my power unit, you create several frequencies within a space of the collector coil's
circumference. The frequencies are directly related to the circumference of the collector coil. You can begin to collect the current and dissipate it with no need for amplification because the signal source also becomes the feed for the power source and has the natural tendency to run with gain."
A simple model of a radio receiver is that you have a resonant LCR circuit which is set to resonate at the frequency you want to tune in to. The incoming radio waves resonate with the LCR circuit. You then extract the modulated signal from the incoming radio waves.
It is the 'kick' that extracts the excess 'electrostatic' energy. Tesla is very clear about this. The bigger the kick the more energy you get out. The more energy you put into creating the kick the more energy you get out. So this aspect satisfies the 'running with gain'.
Perhaps there is an optimum number of 'kicks' per second. The 'kick' causes the earth's Magnetic Field/Ionesphere (MF/I) to respond. If the MF/I pulsates or has a frequency then for optimum energy transfer you'd need to pulse at this frequency. Obvious contenders are schumanne resonance approx. 7.6Hz and ferrite resonance 173.75KHz.
Tesla also observed that certain metal solid shapes and volume optimised the energy transfer. To me this suggests some sort of standing wave in the solid. Which in turn suggests that this 'electrostatic' energy has a specific frequency. So perhaps we have an Ionesphere that pulses which in turn delivers electrostatic energy which pulses at it's own frequency as well. Hence the need for multiple frequencies. The number of 'kicks' per second must be correct but to collect you need another frequency set up as well ?
Now Steven Mark says "the frequencies are directly related to the circumference of the coil". What are the implications of this statement. If there is a wave which goes around the coil then for a standing wave you need the circumference to be a whole multiple of the wavelength of the frequency. So what comes first the frequency or the circumference ?!!
Working backwards from what we do know about the TPU. We know it suffers from eddy currents and excessive heat which in turn implies large moving magnetic fields (but not necessarily alternating). Given that Steven Mark has said the output is mainly DC with a small 6Khz A/C component this suggests the magnetic fields are not alternating but rotating in one direction over a toroidal wound conductor giving the main DC output.
For the 6KHz AC to be a small component of a large DC component this MUST have come from another source producing an alternating magnetic field that intersected the output coil.  I was originally thinking that you had to rotate the actual position where the  'kicks' are generated. But now I think Steven Mark's generates a small 6Khz rotating magnetic field which is used to rotate the electrostatic field. Rotating charges cause a rotating magnetic field. Correctly timed 'kicks' will cause the electrostatic field to build up, which in turn increases the rotating magnetic field and hence the output. Use some of the output to provide higher voltage 'kicks' and you have a positive gain situation happening.
So the 6Khz input magnetic field is like the LCR circuit of the radio which allows the conversions of the electrostatic energy into a much larger magnetic field which fits in with Steven Mark's idea that the principle is 'like a radio receiver'.
If we don't try to do any feedback of the energy then we can avoid the positive gain runaway situation that destroys equipment. It'll also be a much simpler design. This is now looking a lot more doable from an experimental point of view.
Proof of Concept
1. Get some equipment to generate some high voltage pulses which in turn fed into some litz wire will generate the kicks. I'm initially thinking ignition coil type of set up where we can alter the rate of 'kicks'.
2. Four normal coils with ferrite core to generate the small input rotating magnetic field. Input sine wave into 1 pair of coils, other coil driven via a parallel (or is it series ?) capacitor to give 90 degrees out of phase for the other pair. i.e. a simple two phase setup. As we're not trying to prove overunity in this proof of concept but just to prove that 'kicks' will increase a small rotating magnetic field into a larger rotating magnetic field we can rectify mains voltage down to 6-12volts AC sinewave and use this as the input sinewave.
3. Torroid coil around the circumference to collect the output.
Safety: Can we turn it off if unexpected excess energy appears ?
Answer: Yes, turn off the mains and the circuit doing the kicks.
I'm going to give this a whirl. Might take some time though.
Any comments appreciated.
gn0stik
Perhaps we need to look smaller(in principal). What is the most widely accessible, and reproducable free energy device? We've all probably built and used several, and have them around the house.
A crystal radio. Expand the concept out to what we know about the marks device.
He was an audio engineer before this after all.
