The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
0 Members and 31 Guests are viewing this topic.
tao
When at once we played amongst the cherry groves and soared to the highest heights, now we wallow in the droves and see frightful sights.
My time was grand, my era superb, but now my time has come to pass as I say this fateful word,
goodbye,
gentlemen,
it has been fun...au revior
raburgeson
Although the Earth's magnetic field seems weak the vast area that can be drawn from can actually turn the wire to vapor. Be careful keep a fire extinguisher handy and if you are getting any kind of results set a shield over your work. It's not much but I grabbed the old ladies cake holder cover, it's stainless and heavy glass top, enough it , might help? Wear gloves, use one hand on the circuit, we know this stuff guys and I'd rather see us all leave in one piece.
dean_mcgowan
is there a post somewhere i missed .. because everyone has left and there is some kind of claim they have a working model and half the posts are missing .. can someone please explain whats happening here .. ?????????
pese
For Stubbelfield /Mc Farland Patent following : .
I find my datas (written from me in german 3years ago...)
Winding details are 65 to 23 windings
here my german txt with more details:
Kochs Daniels McFarland Elektromagnetische Batterie
Hundert und drei?ig Jahren vor Koch Daniels McFarland aus Mansfield,Ohio
patentierte Dieser  eine "elektromagnetische enrgieerzeugemde Batterie"
Er gab an, da? DIESE:"Einen konstanten Strom ohne Fremdenergie wie,
z.B. einer galvanischen Batterie, produziert".
Sein Patent Nr. 119.825 wurde am 10-10.1871 herausgegeben.
Dieses war, acht Jahre bevor Edison die Gl?hlampe erfand.
Man vergleiche die zwei gegeneinander gekoppelten Spulen mit der Anordnung
der Testatika und des Hendershot wie Coler Generators.
Das Wicklungsverh?ltniss ist 65 Windungen und 23 Windungen
Es ist  wichtig, da? die Sekund?rspule an in der gleichen Richtung
wie die Prim?rspule gewickelt werden muss.
Der Eisenkern A kann ein fester Stab oder ein B?ndel Eisendr?hte.
Je feiner die Eisendr?hte sind, um so h?her wird die Ausgangsspannung.
Die Lastwiederst?nde sollen ca. 16-30 Ohm betragen.
Die Ausgangsspannung kann bis 3 Volt betragen.
Der Generator wird durch eine externe Gleichspannung, gepulst,
gestartet
http://pixerve.de/43323/pese.html
Thaelin
Well, I guess the purge is somewhat over with now. Back to the bench and to work on this. I will be a bit sporadic as I will be doing a lot of reading and then re reading. Then a bit of tinkering on the bench.
Lindsay, nice to see you are still here.
sugra
