The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
0 Members and 63 Guests are viewing this topic.
otto
Hello all,
@Stefan thanks, Im attaching pictures like you said but nothing happens.
What Im doing:
For the new people here
In figure 1 you can see what we are suching for: the KICK or in German Einschaltstrom.
This kick is the first moment of switching ON a DC source.
In figure 2 are shown the wires. We have a collector coil with say 23 fine litz wires. The diameter of each wire is 0,22mm. Around this collector coil are 4 control coils. In my setup each control coil has 170 turns. Wire diameter is 0,5mm.
Figure 3: When you have wound all 4 control coils on the collector coil then form a circle with the collector coil and you have a toroid with open ends.
You need three of this coils.
More comming.
Otto
raburgeson
Otto,
I have collectors running sections in series also but am working on the 6" TPU. Mine will not rotate without input or I think it won't. I haven't found and outlet for air filled compasses around here. Got 3 oil filled and I think they aren't capable of following a rotating field. I went on a 24 hr. bender trying to get more than a promising looking waveform  thank god for coast to coast for entertainment during the nights. No power, the voltage dies when a load is attached. I'm beat from to many hours, I've torn it down and took pics, they are not cool to look at (just a bunch of wire, I'll get them up in a while). I wonder how critical the size is at this point. Mine came out 6 1/4 OD. instead of 6". Really I think I have to be wired wrong 2 in parallel one in series.
Ok, I think your coil would be better with a wire between the 2nd and 3rd sections that can be switched to ground. We just lost several members because they didn't have a safety shut down. The coil you are building can reach high Q too. Don't tempt fate, murphy's law, or what ever you prefer to call it. We're family here so don't get mad at me for saying this. The one thing I did learn for sure is you kill the action of the collector from the center. Try it ground the center and the rotation will stop immediately.
raburgeson
I don't know what all disappeared yet still looking, I got 1 pic I'll stick back up cause I didn't see it. I have been leaving the core windings open I hope that's the right thing to do. Some people were puting a cap across.
otto
Hello all,
in the picture you will see a wiring diagram for the control coil so you can then have a rotational magnetic field.
@raburgeson
you must on one end of the coil connect +8-12 V DC and on the other end a function generator (square wave generator with 0-5V output square waves. I dont need a compass. I have a magnetized needle or a little, light magnet hanging over the TPU. The wires of the control coils MUST be wired all in the SAME direction. In this moment no ground connection exept the bases or gates ( if you use MOSFETs) of the transistors are connected with the minus(-) of the power supply.
otto
