The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
gn0stik
Quote from: tao on June 13, 2006, 04:50:21 PM
Abstract of US5487113
A method and apparatus is disclosed for producing one or more audiospatial effects in an original audio signal. A spatially disorienting signal, typically a modified white noise pattern, is combined with the original audio signal. A spatially reorienting signal is further combined with the original audio signal in order to give a listener the perception, upon hearing the original audio signal played back, that the sound emanates from a predetermined direction.
So, Steven definitely knew his audio processing ;).
Yes, that's one of the reasons I figured he might use something like the crystal radio concept. I was trying to get on the same wavelength he was when he discovered it. Knowing he was an audio engineer, and he spoke of the TPU being like a radio receiver, I asked my self, "what would and audio engineer who was interested in free energy base their device off of?"
Now reading this, I KNOW that he's using ELV/VLF/SCHUMANN resonances. You see the spatial disorientation stuff? Read this...
Here's some examples of the different biological effects amplified schumann resonances can cause. Some beneficial, some.... not so much....
http://www.bwgen.com/presets/desc45.htm
What rang a bell for me was this.
while using this frequency i felt a wierd buzzing in my head and even though i knew where i was i felt like i was somewhere else. Can some1 tell me what that was?
hmm.... spacial disorientation perhaps?
He was already working with schumann resonances and fell into the TPU concept after noticing the "kicks", while working on this or perhaps another invention related to them. Perhaps he dropped a magnet next to a coil that was hooked up to an oscope or something and saw a cascade of kicks. Who knows.
I can smell this thing now.... It's close.
Liberty
Quote from: tao on June 13, 2006, 06:19:16 PM
Quote from: gn0stik on June 13, 2006, 05:47:04 PM
We indeed are close.
Steven's theoretical timeline of events:
The idea you laid out above makes perfect sense, he was already using the schumann resonance frequencies in his attempts to make new audio products for his company when he happened upon the concept for the TPU.
So, he grabs what he has around, ie. some bailing wire, some copper wire, some capacitors, some small electronic parts, some crude structure to hold the stuff together, and there is the very device that we see in that first video, the device on which he places only one magnet, the same device that won't operate upside down. This device is turned on by the insertion of a permanent magnet.
A video later, we see his next device, the one in which he inserts two magnets on opposite sides of the device, but as you said, the magnets are in the same orientation around the unit. This unit is also quite crude, but here Steven demonstrates the lighting of resistive loads with this device. Here also, Steven seems to have solved the upside-down-problem, perhaps by using the two magnets? This device is turned on by the insertion of two permanent magnets.
The next videos show three different coil devices, a small, a medium, and the very large one. Each is completed wrapped with electrical tape in a nice ring shape so as to make the presentation of the device more appeasing to the eye and also to hide the device's internals to on-lookers, for the first two devices weren't shown to investors because all the components were in view and they were too crude. The small device is turned on by the insertion of what looks like a small magnet on the inside of the coil, the medium device is turned on by the switching of one toggle switch, and the largest device is turned on by the switching of two toggle switches at over one second apart.
I'd say thats a possible timeline for Steven's development of the TPU.
We are VERY close now...
Put one together and make it produce some power!
More power to ya!
Liberty
gn0stik
HOLY CRAP!!! Check this out!! From your article. (I haven't read it all yet, but it's like SM wrote the damn thing!) This is incredible.
QuoteHow can this stuff be true?! After all, electric and magnetic fields cannot BEND other fields. They cannot affect each other directly. They work by superposition. For the same reason, a light wave cannot deflect another light wave. Ah, but as I said before, the mathematics of the fields around a coil or a capacitor are not the same as the mathematics of freely-propagating EM waves. If we add the field of a bar magnet to the field of a radio wave, and if the bar magnet is in the right place (at a spot where the phase of the b-field of the radio wave is reversing polarity,) then the radio wave becomes distorted in such a way that it momentarily bends towards the bar magnet. And then, as the EM wave progresses, we must flip the magnet over and over in order to keep the field pattern from bending away again during the following half-cycle. The energy flow continues to "funnel in" towards the rotating magnet. Now replace the bar magnet with an AC coil, and vary the coil current so the fields stay locked to the traveling radio wave in the same way. In that case the wave energy will ALWAYS bend towards the coil and be absorbed. Superposition still applies, but this is a COHERENT superposition, so it acts like a static field pattern: as if a permanent magnet can bend a radio wave inwards and absorb its energy rather than simply having the fields sum together without interesting results.
another quote
QuoteThe energy doesn't vanish, instead it ends up INSIDE the atom. Half of the energy goes into "kicking" an electron to a higher level, and the other half is re-emitted as "scattered" waves.
I mean, c'mon, this guy has to have thought of this. He's described it to a "t" and he doesn't even know it.
gn0stik
OK, you're way ahead of me here, I have to read two more articles still. Thing is, I thought I had read almost all of Bill B.'s stuff, science hobbyist is one of my favorite sites re: this kind of stuff. He's a pretty sharp guy. Kind of like a Bill Nye type of dude, he used to have a "ask bill" thing. Cool thing is, he's right in my back yard, so I can ask him if he ever built one. Or if he's heard of SM. I bet they've had a few conversations over the years.
SMC
Sorry if this has been brought up before, but if this TPM is basically an antenna........we need  an expert in coil type antenna tuning or possibly Tesla coil tuning. All Tesla coils and coil type antennas require exactly this type of "tuning" to achieve resonance and amplification. I've been following the Marks stuff for years and this is by far the best info yet! Keep up the good work.
