The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
hartiberlin
The problem we face is,
that all the 3 or 4 TPUs shown in the videos
are totally different setups each and everybody is
concentrating on another one, so it is getting mixed up
all the time...
So if SM could at least point us anonymously into the right
direction how to generate these kicks in an overunity mode,
so that the kick output energy is higher than to generate them,
then we could work from thereone on our own and scale
the effect up...
But the first thing would be to generate the kicks in an overunity
mode so to speak.
Maybe the shockwave thread is a good thing to start ?
turbo
Potential eddies are capable of a structure formation, and they spread due to their particle character as longitudinal shock wave in the area.
hartiberlin
Quote from: turbo on November 23, 2006, 07:21:03 PM
Can you please provide more info on this ?
Do you have a few links to this information and how it can be applied over here ?
Thanks !
turbo
RE shock waves actually auto-intensify when encountering segmented objects.
The segmentation is the key to releasing the action.
This shock wave does not pass throug the windings of the coil but treats the surface of the coil as a transmission path.
The RE wave is quite diffrent from the electromagnetic field generated around a wire.
Some coils wil be better if they are wound as *-filar serially-connected coils, which just means that the wire used to wind them is multiplied over from certain point(s) before the coil is wound.
The reason for this arrangement is that the magnetic field component of the coils is (nearly) zero as the current flowing across the wire is flowing in opposite directions in alternate turns, and so the magnetic field produced should cancel out.
High voltage high frequency alternating current between two metal objects create a solid state "space" exhibiting the attributes of mass, inertia and momentum.
etc. etc.
Grumpy
What do you mean by "RE shock wave"?
Is this the same as recompression?
        -Frank Edwards
