The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
otto
Hello all,
Mr.Mannix reported us a few days ago his test results...
He sayd he saw little wavers at 245kHz and 30kHz. He has a 15" TPU. Now lets see:
15" = 245kHz : 30kHz = 8,16kHz
Most of us have a 6" TPU.
Let us see the values for a 1" TPU:
245kHz : 15" = 16,333kHz
30kHz : 15" = 2kHz
1" TPU = 16,333kHz and 2kHz
6" TPU = 16,333kHz x 6" = 98kHz
             2kHz x 6" = 12kHz
If we divide 98kHz : 12kHz = 8,16kHz
That means a 6" TPU has the teoretical frequency no.1 of 98kHZ and frequency no.2 is 12kHz.
This frequencies are almost the same Im using.
Otto
Revelator
I have just learned of SM's device, I have been prototying various types of magnetic induction devices since the early 80's. I thought I was familar with most of the devices out there and I can't believe I missed this one. I have read a lot of the posts but definitely not all. There is no doubt in my mind that the TPM works and works well. The detractors posting here need to get a life, as they obviously have never created anything, or had an original idea of their own. It is unfortunate that Steve did not share this info rather than going for the money, perhaps he has his reasons. I think that there is only one way to justify going for the money, and that is if it is going to a fund to help humanity. I think it is possible to be open with a breakthrough such as this and still get the money, (full disclosure coinciding with patent filing). Unfortunately it is too late for Steve to do so, and perhaps too late now for any one else to make a difference either. This type of technology introduced effectively several years ago could have changed the world in which we now find ourselves. A world on the edge of a nuclear WW3, partially over, oil resources in the middle east.
I hope to post some info soon on a transformer I have done some experimenting with, that is excited with a PWM, 12 volts and not a lot of amperage. There is a sweet spot around 20 K where the voltage and amperage spikes, right up to 175 volts ac and about 40 amps. The trouble so far is that allthough the readings are there, the energy output is not. I have been studying Tesla and E Gray looking for some answers and I think that a  copper collector maybe necessary(Tesla), or perhaps spliting the postive (Gray) or perhaps both.
Taking into consideration as well, Sparky Sweets device, I do not think that this technology has to be as complicated as SM's torroid.
An earlier post mentioned the wave/particle issue, and I can't help but offer my humble opinion on this, as I think it has everything to do with the nature of the force fields exhibited by a magnet. I only have a grade 8 education and am completely self schooled on these concepts, formulas are not my forte, nor are electronic devices such as PWM's, some one else built it for me.
I think that it is true that every thing in the universe is vibrating. Particles vibrate at very high rates of speed, they are constantly taking in and giving off energy. Due to the taking in and giving off of energy, the mass of the particle is constantly changing, as the mass changes weight it effects the particle's movement or motion. That is why a particle behaves like a wave. People have a strange notion that a magnet comtains eliptical lines of force, I do not think that this is at all true. That is just the way that iron filings align themselves to the poles. Take a compass around a magnetic field and you will see that while it indicates the eliptical shape, it is merely aligning to polarity. In my early thought experiments with how induction occurs I wondered why a current flows in one direction when entering a magnetic field and then reversed when leaving the field. I drew the end of a magnet on a piece of paper and then drew some circles on the magnet end with some arrows to indicate direction. Going into the field the arrows were all pointing down, and then when you get to the centre of the magnet there are an equal number of arrows going in oppostite directions on the conductor, just at the point where there is no current flow. When you begin to leave the field the arrows are all going in the opposite direction now. At that point I became convinced that there was a circular direction of lines of force, and not eliptical ones.
We have always thought of the north and south being of different charges, and further that opposites attract, and that is why a north pole attracts to a south. But if you dedicate a circular direction on the end of a magnetic for a north pole and indicate the opposite direction on a south pole, when you go to put them together you will see they are both moving in the same direction and that is why they will join together. So we can then deduce that there is no north and south as conventionaly understood, just one common field that has rotational lines of force. Now we must wonder why there seems to be two different force fields in a magnet. There are two force fields allright, and the only reason they appear to be of different charge is because you are using a magnet to determine these two distinct fields. If you use a piece of steel they both seem the same, they will both attract the steel.. Whether with a magnet or a piece of steel it is obvious that a circular and ball shaped field of energy exists at each end of the magnet.  Try drawing a magnet and then superimpose over the whole thing a spiralling and expanding as well as contracting figure eight. If you then try to imagine a flow of particles that are continuely expanding and contracting at a very high rate of speed. You can start to picture the particle giving off energy, getting lighter, going into a larger orbit where it then takes in energy, gets heavier and as a result works down into a smaller orbit, takes in energy and goes into a wider orbit again on the other end of the magnet.
I guess that about wraps up my comments and thoughts for now. I look forward to hearing what some of you genius's out there, may have to think about about my theories. I hope they are interesting and even perhaps help somebody, with their experiments.
PS I think that there is another element of current flow that works along with the circular lines of force. Different level of energy though from a higher dimension/frequency that works in conjuction with the lower frequency/dimension. I may post more on this at a later date.
Yamanashi Jr
Revelator,
BushWacker was saying the same thing, but we don't see him around for some time now.
about Magnet properties:
http://www.cheniere.org/misc/sweet.htm
When the party is over
... I just keep dancing to the rhythm
giantkiller
I clipped this from the previous post 'Cheniere'.
One can take the energy from the vacuum in a hundred ways, not just one.  Sweet's way was indeed a very good way.  There are also a hundred other good ways.
I guess we are all not so crazy or 'out there' as some would believe.
Ya gotta love that term 'Vacuum', eh?
--giantkiller. Tnx Grumpy. And of course, all the other dolphins. Keep swimming, keep swimming...
http://www.overunity.com/index.php/topic,1914.msg22312.html#msg22312
vortexentity
I have read this thread for more hours than I can count mainly because I might have read some in my sleep.  ???
It has been kind of like reading the encyclopedia crappanica to find one chapter of hard applicable data. My hat is off to the brave ones who have sat through the entire thing day in and day out for the last year.
The important issue is of course free energy for human kind. I am afraid it is not any closer to us as a result of this device that Steve has shown us fleeting glimpses of in his videos.
Steorn I am impressed with. Steve Mark, and UEC I am not.
Why give out these teasers on a company that is not public? Why frustrate the inquisitive and enterprising with this spoon fed drivel?
After nearly 10 years of public exposure the only reason this technology is still unknown to the world is because it never will become known in my opinion.
Not that this all is not very interesting or I would like most of you not suffered the endless reading of this thread to discover that it does not contain enough information to assemble an experiment based on the systems operating principle.
At least with Steorn in Ireland they gave the public notice. They also gave the scientific community a chance to find out about the technology and be empaneled to give it a critical revue.
As far as I can see Steve Mark and UEC are going to take this one to their graves. Perhaps in another 10 years or so they will be irrelevant as Steorn's technology will be on the store shelves and in our homes while Steve's technology sits on the shelves of some subordinate defense contractors warehouse shelves.
