The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
innovation_station
some info i found on the IRF840 fets it seams that you can light bulbs with them
read the link i posted it is for a ampliflyer
http://www.electronics-lab.com/projects/rf/027/index.html
ist
giantkiller
Quote from: eldarion on April 13, 2007, 11:59:38 PM
@weri812
I'm sorry, I don't see the difference? ???  I must be missing something (not the first time!) ;)
The difference is pictorially slight but a magtitude of difference electrically.
In the 2nd diagram the signal runs in 2 paths. A field is created around the center signal line. Any one who has achieved kicks knows this circuit. The GK4 is wired in the first step as Tesla's 390721 transformer (bucking field coils). These are the control coils. That I wrapped that configuration around iron wire which creates a configurable iron core for the control coils. Just like the second diagram. And per Otto's jumpering the iron cores become the collectors that are the internal feed of the the initial signals. But what this configuration does is feed a dissimilar frequency into the core from another control coil signal. The GK4 rendition could not reach over unity. The controller and collector masses are different.
What has been seen by more than just I is that when the masses are very close, a single frequency is all that is needed to produce resonance, hamonics and beautiful kicks with ringings. The Radiant energy component shows up also in the scope shots.
Now the GK4 is a gross example of the signal line coils fed back through its own collector (self). JDO300's, Otto's, and IS's smaller experiments show this explicitly in a less complicated format.
I will use Sauron's collector loop with all the black bobbins for this next explanation. Instead of driving all these coils seperately like a motor controller would do, we connect all these coils as a single controller but all bucking. Just like IS had done with his BLACK HOLE SUN. I think he knows what he is talking about here. If the mass is matching in that coil then it is appropriately named. You drive this with one frequency and what is impressed upon the collector must drive it crazy! Not to mention the flux collisions that are there.
Definately a Radiant energy pump. 90 degree coupling? Forget what you know. And when this thing ramps up think of the magnetic mess in the center!
And your clue for the day is: There is another musical indentifier (Soundgarden).
In diags the signal is 100khz. It probably matches up with the 50 turns.
--giantkiller.
nong
Hi Gk, Otto
Thank you for explaination.
nong
nong
Quote from: giantkiller on April 14, 2007, 11:11:45 AM
Do you mean iron and copper?
otto
Hello all,
@GK
just 1 question, if allowed:
Why do you use IRON?????
Otto
