The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
otto
Hello all,
I can only hope its a little bit clearer now.
Use:
1. IRF 840 MOSFET
2. 50 turns wire is 0,5mm in diameter, sorry dont know the awg
3. 12V from power supply
4. pulses from oscillator 5 - 12V
5. lamp wire - insulated  or  speaker wire - insulated or ....less then 1 foot long, less then 30cm long, must NOT be a ring, just a piece of litz wire
This and NOTHING ELSE!!! And you will have my results.
Otto
otto
Mannix
Quote from: sulake on April 16, 2007, 06:25:48 AM
So it's the same as this in that how it works.
Can you post some pictures of the voltages from your scope?
Please do the test!!!!!
use the correct components arghhh!
sulake
Quoteyour joking.
No I'm not, but maby I misuderstand your circuit drawing.
In the Drain of the IRF840, there is a voltage of 12V that comes through the 50rounds coil?
If it is like in your drawing, IRF840 only acts like a swich that connects Drain to Source that is in Ground level?
If your pulse generator gives out some extra voltage to the coil, the drawing must be wrong then. That drawing only acts like a swich that pulls it to ground. ?????
Dansway
@Jason,
Ok...Jason!  I'm ready to do the Super Otto 3-coil test!  This coil should be very interesting.   ;)
This is my newest addition to the tpu family.
@Otton,
Thanks for sharing!  Don't worry about anyone's detractions.  Just keep your compass pointed in the right direction!
~Dan
