The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
Mannix
I hope that people are not thinking that the story was from Steven,
Joe had it straight up!
Bruce_TPU
Well Lindsay...OF COURSE WE DID!!!
WHEN YOU SAY, "Hello all,
A very nice story recieved from our "Edison"of tpu's
Who else would we think it was from?????????????
Just say what you mean and mean what you say.  I for one am very sick of riddles.  This is too important to be playing double speak.
Can you say, "HACKED OFF!"
The story was from Otto.  He is back from his spiritual retreat, which I admire.  But on your post, why not just say "Otto".  Type it, it is four letters.... "OTTO"  see, easy!
devilzangel
@btentzer .. so much for your "hint" from SM/Mannix .. it isnt a hint to anything .. seriously, u need to take a step back and take a breather, and stop thinking that everything mannix or SM say is somehow a clue to the TPU .. these guys arent super cia agents who talk in codes ok. No analogies or metaphor is going to help u .. only your own understanding of the electronics, intuition and experimentation will do u any good.
i agree with Jdo300 .. there is a learning curve .. BUT let me ask, do all of us who use TVs, laptops, cell phones, etc, understand the inner workings of those components??? .. simply not. we use them. i simply dont buy this bullsh1t about 'you have to understand in order to use' cr@p.
the USA govt is blocking all innovation and invention that can help humanity for the sake of military superiority.
devilzangel
bob.rennips
Quote from: Mannix on June 02, 2007, 11:50:13 PM
Instead of the quaint story why did you not just write.
"Heads up everyone. Otto appears to be making great progress and has some interesting results. Please take a look at xxxx thread.".....
Too easy huh.
devilzangel
@ Mr. Mannix,
I have nothing against hearing good stories .. but this is neither the place nor the time to be sharing such. .. Why am i telling u that? .. I am sure you already knew this, otherwise your wouldn't have started this wonderful project in the first place.
if u insist on posting over 50 lines of stuff that doesn't help us understand the TPU, we are most probably going to just scroll through it without reading a single line. I read through it thinking there was something important in it, otherwise you wouldn't have posted it.
lets stop with this analogy and metaphor stuff .. use those ONLY when people dont understand the concept in scientific terms. Don't use them as the actual concept itself. .. again, i feel like you already knew this.
devilzangel
