The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
gn0stik
Quote from: tao on June 23, 2006, 04:03:15 PM
Quote from: gn0stik on June 23, 2006, 03:45:38 PM
Remember that it also depends on how we arange them as well, If the top and bottom collectors are connected in series, and the middle coil is parallel to both of those, we can't really pump in frequencies from either direction without changing polarity. Unless you have more than one connection to them, in order to do it.. (Remeber steven saying "I tried it, and it works!") This is because they are essentially one long wire making two coils.
As to your video Tao, that's pretty interesting. That's the kind of effect I was expecting to see, with the magnetic field causing inductance into the center coil as it spun around the toroid directionally. Kind of reminds me of those socks I got for xmas last year, that I never wear, though.
IF this method is correct, then you only need three connections. Two from those central controls to each with a different frequency, just like Steven said in the video where he turns on the first then second frequency. Then you would need a third connection for the output. None of the 3 toroids(coils) would be connected to each other.
Then again, if we think in terms of PULSED DC and the Tesla radiant then the frequencies in the different coils would still be opperating at a frequency, just not AC ones, only pulsed DC ones, so no reversals of current would be allowed.
The interaction from these pulses then explains the KICKS and how they can combine into larger kicks, and the MOTIONAL FIELD could still happen through the interactions of these PULSED DC impulses based on their frequencies.
More later, I'm rambling on :P
If you go back and read his letter, he defenitely infers that the coils are connected to eachother, and that we should experiment on how they should be connected. At least that was my impression
QuoteIt is three separate coils of multi strand copper wire laid one on top of the other, not interleaved. Three is important. You can do many things with three coils. You can run them in parallel, you can run two in series and one in parallel, or etc.
tishatang
In regards to freq generators:
Instead of MAX038 which seem hard to get and expensive, why not use cheap CMOS flip flops like
74ACT74?
link:  http://www.futurlec.com/IC74AC00Series.shtml
Only costs $.28  and 6nS cutoff time.
I am not technical and maybe I am missing something obvious.
Tishatang
bob.diroto
Quote from: Lance on June 23, 2006, 03:55:53 PM
Please has anyone performed an experiment to rotate a magnetised core inside a simple toroid at a constant speed (i.e. simulated moving flux). Can anyone answer if this would cause a DC voltage to appear at the coil wire ends?
Yes it would. But just because there is only an A-field outside the toroid doesn't mean you won't get back EMF effects. You do get back EMF effects.
But if the rotating magnetic field is created as a side effect of the kicks and some synchronising with the ionesphere to somehow tap into excess energy then you will get a DC output that is overunity. Thus unto how do we convert electrostatic effects (kicks) into magnetic field effects...
bob.diroto
Very nice Tao.
Also have a look at what happens when you have two frequencies that are the same moving in opposite directions. Quite obviously a standing wave. BUT look what happens when you alter the amplitude of one of those frequencies. You get a sort of rotating effect with the pulse.
Now if the circumference is whole number related to the wavelength you're going to get those standing wave pulses occur in the SAME place on the coils.
How do you get a moving STANDING WAVE... I first thought change one of the frequencies slightly but then you get the effect that you've shown on your video, which I think certainly needs investigating.
Then I realised once you've got your frequency that is whole number related to the circumference if you change the frequency slightly that goes into both coils the point of meeting will move slowly round but without the 'capsule' effect.
bob.diroto
Observing the magnetic field in the empty space of the toroid.
Will filling a coke bottle with a mix of glycerine, water and very small iron filings allow this field to be seen in motion  when the bottle is placed in the center of the toroid ?
