The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
0 Members and 42 Guests are viewing this topic.
Dingus Mungus
I have spent the last few hours simulating square wave variations of the Schuman Resonance, my findings were that no anomalys spike were observed by the scope. This simulated frequencies package can be useful to experimenters that do not have the time or components require to replicate these pulses with electronics. I can simulate anything you need from .01Hz - 22050Hz, and you can use a linear amplifier and your soundcard output to power your coils.
If anyone wants me to generate a custom set of frequencies PLEASE REQUEST!
I can export 2 tone wave files so left is frequency 1 and right is frequency 2.
I hope I can further assist in this area of the project...
starcruiser
Quote from: ctglabs on September 29, 2006, 05:47:43 AM
Dear all,
For those interested in looking for the signal mixing and kicks in two transformers with different phases, I present a simple circuit which is yet to be tested, so may require a little de-bugging.
Basically we have two square wave generators, we can switch between (SW1) using just one of them and having two phase shifted outputs, or we can choose to have two frequencys and shift between the phases (of course changing two frequencys would give give a kind of shift too!>!).
These outputs are fed to the primary of two transformers, of course you connect these however you want and in what order you want, or even mix it all in to the primary of one transformer.
VR2 alters the phase shift, but be aware that say 90 degrees on one frequency, wont be 90 degrees on another, whichever phase must be adjusted with the adjustment in frequency.  The outputs are then buffered before going to the transistors which can be whatever you have laying around as long as they are enough to run the transformers, etc.
Regards,
Dave.
Dave,
Looks good, one question though, didn't Tesla use short duration pulses? I am not sure so I ask, can you design this to vary the duty cycle? I feel this may help. We may need a 20/80 or 30/70 cycle (On/Off) to improve the test results.
Just a thought.
Carl
Regards,
Carl
gn0stik
OK, I just had a thought. Are we all chasing rabbits trying to measure the kick in the first place? Seems to be if the Kick phenomena(radiant flying off the surface of the wire at 90), is due to the "bunching effect", and electrons are not flowing through the full length of the wire we are measuring yet, but instead causing energy to leave the circuit at right angles... Wouldn't we have a VERY hard time measuring the kick on anything but the collectors? And even then, if the energy that we are trying to measure is radiant energy, is it measurable at all with std equipment?
This occured to me, as I've seen a few posts that were analyzing theoretical waveforms, trying to find kicks, etc., and I thought to myself, "is that even where kicks occur?"
Am I too far off base here? Am I making sense?
Dingus Mungus
Quote from: gn0stik on September 29, 2006, 10:10:21 AM
I'm unsure of this as well...
Altho Mannix and Marks both made refrence to Marks observing this kick effect before developing the first device, if memory serves me, the effect was witnessed in out of phase transformers in series and vacuum tubes. If we can measure anomalys spikes in either instance, it may give us the resonant frequencies to calculate harmonicly tuned coils needed for the device. On the other hand the kick effect witnessed in the transformers or vacuum tubes may not be the kicks we are looking for but phantoms that are similar in nature but not amplitude. I feel we need much more information, the info provided thus far is interesting but not enough to precisely test anything directly related.
Why would Mannix or Marks hold back helpful data that doesn't refer to the patented device? I guess we'll just have to hope the patent lapses one day so that anti-replication clauses, nondisclosure agreements and licensing fees will be nullified, then perhaps Mr Marks will finally share the secret to world peace and postmodern civil sovernty.  :-[
jacob
Hi Dave,
And by the way thanks for yesterday's welcome.
Quote from: ctglabs on September 29, 2006, 08:31:24 AM
If you are using one vertical and one horizontal coil I think I can see that rotation could infact occur with sine wave!  But not if using square wave?
This could be how SM has rotating field with very simple setup?  But he says the horizontal coils are for collectors, not for control?  Also in the large SM device, many wires can be seen coming of the torroid and going to the centre, which indicates more coils as he says.
You are right about the collector coils. We have to apply the sine waves to the control coils. The rotational inertia and gyroscopic effect is produced horizontally, not vertically. The reason Otto got results from his setup is because he feed back the output signal to the input.
Now regarding square waves vs sine waves, here is what I think is happening here:
Kicks are said to be happening when current is first set to travel through a conductor or when the flow is abruptly stopped. Now these sudden changes in current are like a square wave. And it can be shown mathematically that square waves contain all the other frequencies. Therefore when there is an abrupt change in current flow. The electrons that travel through the conductor are not set in motion linearly but start to oscillate going through the whole spectrum before the flow becomes uniform. As this happen, the "right" frequency is produced for a split second. But since the circuit is not tuned to this special frequency were the conductor interracts directly with the earth magnetic field, the kick is short lived. So to be able to observe a kick in a plain conductor, a square wave need to be used. But if the circuit is tuned to the right frequency, we can keep tapping into this energy. So the TPU can and in fact does operate with sine waves. Therefore, 2 simple tuned LC circuits is all it takes to do the job.
Regards,
Jacob
