The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
0 Members and 51 Guests are viewing this topic.
kames
Before saying anything else I would like to direct my question to Steven Mark. And here is my question:
In at least one of you devices, does the OUTPUT AC component frequency increase PROPORTIONALLY with INCREASING the number of turns in the output coil?
This is not a funny question, this has been achieved in one of my experiments. I would really appreciate and respect any answer from Steven, even no answer at all. The answer would definitely help me to verify if I am going in the right direction.
And here is some more info.
I am a new in this forum as a registered member but I am not new in this field and in tracing this forum, at all. I have set up one (after a year of experimenting) experiment where I have managed to multiply electrical ?kicks? that Steven Mark was talking about. I have not managed to naturally generate initial ?kick?, at least yet. The electrical ?kick? that I was using was generated artificially but it did got multiplied. I am not yet ready to reveal everything. I might post more info after I get a stable and easily reproducible results but PLEASE don?t be disappointed if I don?t. As Steven said, I don?t like ?Monkey see, monkey do? approach. Unfortunately the things are not moving fast enough.
Some info, only based on my own experience AND after looking at Steven?s videos again and again and some experiments:
1)No magnetic core CAN be used, at least in the simplest set up. In some videos it looks like that the magnetic core IS being used but I think that was some technical improvement vs. general approach.
2)Magnet is a mandatory part but not the best solution, just the simplest solution
3)Look very carefully at the videos and/or some screenshots. There are at least two pictures that do reveal too much. (I don?t want to say that I am absolutely right, I might be wrong)
4)Some of the postings is this forum do really have very interesting stuff
Thanks a lot to Steven
rensseak
Quote from: hartiberlin on February 20, 2006, 08:59:02 PM
Lindsay and Steven.
Many thanks for the infos so far, but I am also pretty busy with other things right now,
so I have no time to do these tests. Also I have tried to look up the effect
of the kick current with Google, but did not find any experiment,
which can prove this.
ALso the tube valve book is not available over here in the libraries
and I hoped, somebody would scan it it from their local library or
somebody, who has this book in his posession...
Just keep the info flowing. This year there will
also be many more interesting new devices come up, I can not yet
speak of, cause I have signed NDA.
Regards, Stefan.
Hallo Stefan,
Mit "first kick" ist offensichtlich der Einschaltstrom gemeint.
http://de.wikipedia.org/wiki/Einschaltstrom
Wie das jetzt aber mit dem Erdmagnetfeld zusammenpasst und ob die Begr?ndung wie sie bei Wikipedia steht so stimmt kann ich nicht sagen.
MfG
rensseak
rensseak
Hallo Steven Mark and Linday Mannix,
first of all, many thanks that you are willing to give us some lesson, otherwise we must again invent the wheel.
My english is not perfect, so i want to know if the "first kick" you mention is the same as "startup current" or "starting current" in german "Einschaltstrom" or "Anlaufstrom".
regards from Germany
Norbert K??ner
oouthere
After rereading, I'm obviously getting tired.  I thought the idea was to take an unknown induced voltage and jolt a dead battery(Bendini styple o/u).....obviously brain dead again.  The actual idea is to see the copper movement with a sudden jolt of power, and the true quest is what the copper is reacting against to move which is apparently the earths field since the low gauge copper cannot be heated fast enough to cause a physical jump.
Sorry, I'll try to pay more attention in the future....
Rich
rensseak
Hallo Lindsay,
ok, next question!
steve said it would be in common sens, but you said it is new education. I'm now irritated.
I was somewhere reading that every electron has a spin and a north and a South Pole (http://www.physorg.com/news9125.html) and "when first electrons are caused to flow in a wire" the adjustment of this poles or spin is changing and this gives the kick.
regards
Norbert K??ner
Quote from: Mannix on February 21, 2006, 08:17:42 AM
Rennseak,
Good question
You are looking for prescribed terminology I am sorry your training does not include this .....it still doesn't
I quote from Steven directly here ..."when first electrons are caused to flow in a wire"
unquote
This is the first gold nugget ....do not try and fit it into your education this is a new education
Every body has been looking for back emf
The kick is physical...it shows that there is ENERGY!!!
It is to prove to you that it is there
It is to remove your doubt
It is the foundation of you knowing that it exists
I sincerely hope this helps with the context and action of the KICK!
Does any body else think that one kick amounts to any thing?
Perhaps we need more than one kick ...who knows? ...
What if we had a switch that could turn off the moment after we turned it on?
Heres a potentially stupid term"foward emf"... no sparks ay? ...
I hope this makes sense to you, it is a slow process.
If I could down load my brain here it may help ..I feel like I already have
Im sorry but I keep repeating "read the thread again"
But yes a good question!
Lindsay Mannix
