The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
Mr_Video
K.I.S.S.
I agree with some of the posters here that we need to step back from all the theorizing and outright guessing about how SM's TPU is built, based on some fuzzy videos .
I want to see someone succeed in building a working TPU as much as anyone, but the best place to start IMHO is the same circuit that SM started with,
a 5U4 power supply .
it's easy to build (no guesswork) and most of us can build one from memory & readily available parts, and even if you don't have a 5U4 on hand, then make one with 2 diodes an a resistor (it's where I would start if my lab was set up)  :)
and then start playing around with the phase between the 2 output windings and look for the anomalies that SM was talking about, and go from there . :)
QuoteI originally got the idea from electron circuits which use vacuum rectifiers like the 5U4 GB or 5AR4 etc.  The plate has a high voltage potential with lots of useable power available. You cant get to it or use it for anything without applying a heating voltage to the cathode or what is the cathode potential of the tube. So, you put in a small voltage of 5 volts AC 60 Hz which heats up the cathode and welcomes the electron stream from the plate. Or actually the other way around, but not important for this example of my thoughts. Now the high voltage power goes through the cathode and travels through the coils of the 5 volt transformer along with the 5 volt AC. if the plate voltage is not rectified then it is AC with a potential 60 Hz frequency. That combines with the 5 volt 60 Hz in the coil of the htr transformer and generally amounts to nothing. In fact the power of the 5 volt transformer amounts to nothing. It is an insignificant power supply except when the two transformers get slightly out of phase with each other, or when they are connected in reverse of one another.Then you can measure all kinds of things going on. You can generate all kinds of hash and multiple frequencies, and I do mean all kinds. What I measured during this process was very interesting. All these frequencies occasionally met at the same time with a much larger kick at the output.
giantkiller
@Kosh
You're right about the lateral resistance. That is because the center of the toriodial field is in the center. With harmonic overlapping of 2 counter-rotating magnetic fields I will be able to vary the field strength to push the center off to one side. This will give an imbalance and the toroid will easy go towards the side of least resistance. Much like the image of a sideways teardrop until re-centering is gained. The magnetic bubble off balance has been proven in physics. I saw it some years ago in another study when I was following the building and construction of the Tokamak. http://en.wikipedia.org/wiki/Tokamak
And that is area of toriodial operation I am aiming for with the controller I am building. I did post the schematic at time back, post page 211. The step after I run my coil is to focus on making a bigger one that is flame retardant. I plan on smoking the one in my avatar.
Big field, big fun. ;)
Later.
supersam
mr video,
why can't someone computer enhance the steven marks videos?  is just because they were shot in the ninties useing whatlooked to be sixties 8mm? that is with no lighting enhancements.
lol
sam
ps:what is my reading list for tomorrow , rich?  i will guarantee it will not just be here.
have you got some more old theoritical stuff that no one else has figured out except you and them?  come on this is the computer age lets bring it on-line!
raburgeson
Alright, wish I had more time, overlooked, listen carefully, failing because you don't know how to read.
Said in pertinent posts,   posted (output perpendicular to many wires),  first clue on this, Posted (if you draw a magnet the lenth of a wire) or the lenth of many.
Make detailed notes on everything said and compare notes, Steven is not trying to teach you to understand the Moray device or any other than his own. I have coiled wire both laterally and longitudely around my coil.
I have changed my configuration of number of coils on the toroid because of math problems, I have not however abandoned Steven's theories set forth. Imagine a rotating magnetic force traveling though wires wraped so the force cuts lenthwise.
energyman8
Tao,
Im reading you, great information  :D
Are you part of the problem or part of the solution? ;D
