Beslaurentius code or how to harness the Mikovic pendulum power on a Bessler way
Started by woopy, March 30, 2009, 08:24:49 AM
woopy
Hello all
here under you will find a code in 9 phases to rotate a wheel by the mean of gravity+swing energy storing +torque recuperation of this energy
yesterday i tried it with only 2 fulcrums
by a single swing of 1 fulcrum (the other  stay chopped on the wheel), i can get almost 1/2 turn.
the speed of the wheel is very important and must be controled to stay constant the power of the wheel depends not from the spinning speed but by the increase of the torque by changing the inclination of the wheel from flat (no rotation and no torque to vertical (max torque)
so i think that with 4 or 5 fulcrums we can harness the power of the Milkovic pendulum to spin the wheel à la Bessler
i have breefly discusssed this system in energeticforum.com under the Peter Lindemann thread "the mechanical engine" but i think there will be also interested and or experienced people here
Now i have to find a good chopping  and releasing system and perhaps ::)
waiting for comments and suggestions
and now back to the workshop
cheers
Laurent
grayone
woopy ; I find you wheel interesting. Using a ratchet paddle on a chaos pendulum effect. My biggest question is. How will the swing of the pendulum working with the ratchet be controlled?
hansvonlieven
This is a very awkward way of going about it. Much simpler is the double ratchet drive that is illustrated below. It drives the ratchet on the upstroke as well as the downstroke regardless of stroke length. It works very well with the Milkovic device converting the irregular oscillating movement into rotation. Sorry but no overunity though.
Hans von Lieven
mondrasek
Laurent,
I have had a blast simulating these types of designs with WM2D.  Have you considered that?  It would be fairly simple to do but you would probably want to have the components drawn up in CAD so you can import them as DXF files.  The simple drawing tools available in just WM2D make precise work with complex geometries quite difficult.
If you do not have these capabilities I can try and work something up for you later in the week.  I should have some time on Wednesday or Thursday.  In the meantime, you could get a copy of the WM2D demo on a machine that can run it so you can view the sim once I send it to you.  Unfortunately I have not had much luck with the video export function of the program.
A simulation is not perfect, but if no OU tedencies are apparent in the sim, I don't think a build would show more potential.  Plus it's a great way to try many ideas quickly as well as find what optimizes even those that do not work.
Thanks,
M.
hansvonlieven
@ mondrasek,
You are right, the video function in WM2D is not much chop. I found though that if you leave all colour rendering out and work with outlines only it's not too bad.
For what it's worth.
Hans von Lieven
