is it possible to mimic a homopolar motor with permanentmagnets?
Started by Low-Q, March 30, 2009, 06:02:23 PM
Low-Q
Quote from: broli on April 06, 2009, 10:02:18 AM
Looks like your ignorant self is back too denying every single step I do. How can you not f-ing agree on what the simulation is showing you ignorant person. I used solely magnets in that simulation and if you used 1/100 of your brain the field will make sense too. How they hell do you expect to make any progress with this beyond belief ignorance. Makes kind of my blood boil.
This is why I'm starting to hate you big time Vidar. You throw logical thinking out of the window and replace it with disinfo to sabotage others from making progress. Do you sometimes even think of the crap you spread and the damage that it makes.
If the field is orientated up that's how the ELECTRONS ARE ORIENTATED. Unless you change their orientation the field will always come out from the same spot. You cannot assume that a vertical field is the same as a horizontal field! I truely expected more from you Vidar you are a big disappointment.
Yes, broli. That is really grown-up. Go on and hate everyone who question your results and theories, and the world will become a better place. Come on! Get over yourself, and try to look for your own faults. Look at the simulation below. What do you see? I cant see how the sum will make a circular magnetic field. Do you?
You can still hate me, even more than big time - it's all OK, but that will not change the magnetic field. I just asked you to check your results and your simulation setup once more. And you hate me for it. That is really the way to make progress!!! ;D
pese
Quote from: pese on April 05, 2009, 09:04:54 PM
in princip
is an homepolar motor near 100 jears invented
I ave on in my hand (found today)
i loked in google:
Invented 1927 by Siemens and Schuckert Werke -SSW-
it is an 220V (up to 20Am) DC ! Line power counter.
DC as line voltage was used in Germany up to 1960
(in some cities , additional to AC line supply.)
So that part ist also (ac AC Counter) using an
Alumium DISK . I will not open my device amd can not
understand that it can produce EDDY-Currents ?
Sie the LINK. the forst device i have.
click-up the pictueres that show also the inner construction.
This device will turn an counter !
So than: That is an MOTOR !
Now i will scratcing my head - and wonder...
Pese
SORRY i forget to send some links and pictures.
-tanks to ask for that in an messager
Translating. Gleichstromzaehler = DC Cirrent Meter
(Correct COMSUMPION METER)
http://normalzeit.info/messtechnik/zaehler/z.html
http://normalzeit.info/messtechnik/zaehler/gs1.jpg
http://normalzeit.info/messtechnik/zaehler/1a.jpg
http://normalzeit.info/messtechnik/zaehler/gs2.jpg
http://normalzeit.info/messtechnik/zaehler/gs2a.jpg
http://normalzeit.info/messtechnik/zaehler/gs3.jpg
http://normalzeit.info/messtechnik/zaehler/gs3a.jpg
SURPRISING.. see above.
BECAUSE : THIS IS AN DRIVEN MOTOR , this princips must be to
use also to enlarged to Power driver Motors....
Pese
Low-Q
What is that yellow "doughnut" doing?
That ball of thread and the coil under looks like it works like a squirrel cage induction motor which rise RPMs as the AC-current flow increase, but with several vindings instead of the solid core single winding you'll find in normal squirrel cage induction motors.
Br.
Vidar
pese
Quote from: Low-Q on April 07, 2009, 01:57:52 PM
Br.
Vidar
Give ATTENTION !
THIS IS FOR DC use !!!
NOT AC Power-Line counter!!
I let you know
because the ASK was : It is possibel to do this with permanent Magnets.
DC powered coil are elctromagnets for same use in same application  as permagnets
I cant say nothing over the work of this Motor.
I will open my originalle closed Counter from 1930 nxt da and see inside,
It is the SSW 220DCVolt 20Amp type from Siemens$Schuckert
Think about, no brushes , no contacts inside.
It will work  with low voltagages and 0 to 20 Amperes.
Pese
Michelinho
Hi pese,
Can you take some pictures of the inside as you open your meter?
Thanks,
Michel
