Sjack Abeling Gravity Wheel and the Worlds first Weight Power Plant
Started by AquariuZ, April 03, 2009, 01:17:07 PM
AquariuZ
Quote from: Omnibus on April 22, 2009, 02:07:39 PM
@Dusty,
Here's my first attempt to draw your rotor (my buddy @X00013 will be proud of me, just kidding). It can be exported in a dxf format (haven't done that yet) to be used in a CNC machine. Wonder if CNC machines can handle details of 2m diameter? If you find that you may have any use for it just let me know and I'll try to send you the dxf file. Also, abviously, improvements have to be made as we go along.
Omnibus, nice, but the legs should not point to the axle, please check the pictures
If you have a DXF file you can import it in wm2d BTW.
Omnibus
@AquariuZ,
Quite correct. That's inertia (no pun intended) from the wm2d modeling. Will have to figure out how this non-radial thing is done. Hockey stick grooves aren't right either.
itanimuLLi
@ All ,
How about this concept applying on the Abeling wheel, can anyone make a simulation on this. I don't have wm2d so i couldn't follow everything maybe somebody came up with this...
Omnibus
@Dusty and @AquariuZ,
Here's a slightly improved depiction of Dusty's rotor.
Omnibus
@AquariuZ,
Unfortunately,converting this to dxf file turns out not to be as straightforward as I initially thought. If you think you can convert any other type of file into dxf just let me know so that I can post it if I can save it in such format. Would be good to be able to import the above file and try to model @Dusty's device in wm2d.
