Sjack Abeling Gravity Wheel and the Worlds first Weight Power Plant
Started by AquariuZ, April 03, 2009, 01:17:07 PM
0 Members and 76 Guests are viewing this topic.
AquariuZ
Quote from: Cherryman on April 08, 2009, 08:50:53 AM
Well i'm not visualizing you'rs or Sjacks idear.  This is work i dit past month.  I have a few more setups, but because I cannot save the WM2D files i have to create everything again from startover.
But i'm glad you like it.
I like it because I see serious overlaps in the way I think the Abeling Wheel works...
Just thought of this: canyou try and make the barrier straight with a slight curve to the right past the axle and see what happens?
I am just starting a new model. Did you see my previous wm2d model? Thoughts?
Here it is again the first try at the shot-put principle in wm2d: http://www.gigasize.com/get.php?d=yz59m4y7wqd
Cherryman
Quote from: AquariuZ on April 08, 2009, 08:57:15 AM
I'm sorry but i cannot open WM2D files, because i only have the demo version. So i did not see them, would like to, do you have a movie ?
And i can do something you like, but you have to be more specifick.. a drawing maybe?
Or did you mean something like this?
http://www.youtube.com/watch?v=d8QK8w2sw8Y&feature=channel_page
AquariuZ
Quote from: Cherryman on April 08, 2009, 09:00:08 AM
Yes this is what I mean, try and see what happens without the motor driving the wheel (just pin it). And a straight barrier which curves to the right past the axle.
I do not know how to make a movie from a running wm2d model unfortunatly.
How do you create the arms? Are those polygons? I find it difficult to work with hollows in wm2d
Cherryman
Quote from: AquariuZ on April 08, 2009, 09:11:21 AM
I do not know how to make a movie from a running wm2d model unfortunately.
I Created the movies with a free and simple screen capture program:
http://www.nchsoftware.com/capture/index.html
I use Rhino3D to design the structure and then import it in WM2D.  I have found a workaround for the hollows , i make a tiny opening in the loop so it is a polygon.
Try to make the opening as small as possible and if possible in a place where you will not have contact with the ball so it will not influence the setup.
Here is a picture to show the concept:
Cherryman
I got some requests about sharing the files..
I have no problem with that...  But i don't like it being called Abeling  >:(  I haven't heard or seen from him untill yesterday... And just apart from a few vague pictures we don't know anything about that machine.
So as i'm not trying to keep this for myself, i do have some vanity..  So i call it the K.A.D. system!   ;D
