Sjack Abeling Gravity Wheel and the Worlds first Weight Power Plant
Started by AquariuZ, April 03, 2009, 01:17:07 PM
ramset
M
From point A to point B with the same amount of "fuel" [the drop]
The long road ball gets more done "faster"[does more work "quicker" with the same amount of Fuel]
I did not know this was possible ?
And I don't know of anyone that has used this extra "Zip" in a wheel.
I believe that to be Omni's point.
Chet
PS
That being said ,if the above is true and not a scam [the Vids]
No one has come forward to say this is Bogus.
Omni has a "Very" good point. Abeling said his "idea " is nothing New
Just overlooked or forgotten.
Thanks Grandma
mondrasek
Quote from: ramset on February 26, 2010, 10:47:14 AM
I believe you are correct.  But as Fletcher indicated, in order to use this extra "Zip", you have to tap into it while that extra speed exists.  At the end of the ramp, there is no extra speed.  And if you tap into it anywhere else, you have tapped into it where the ball on the longer track is lower that the ball on the straight track.  Siphon off any of that higher velocity and what happens at the end of the track?  Either the ball will not have enough velocity left to reach the end of the track or it will reach it with less velocity than the ball on the straight track (even if it might still get there faster).
So the extra "Zip" must assist with the rotation of a wheel but not impart any energy to it somehow as far as I see it.  This would seem impossible, or at least counter-intuitive (as John Collins might say).  So it is something at least to contemplate, I'll give you that!
ramset
M
perhaps a faster "arrival time" will make a difference in some part of the the wheel?
Chet
Thanks Grandma
mondrasek
Quote from: ramset on February 26, 2010, 11:13:12 AM
Chet,
That is the part worth contemplating!
M.
Omnibus
