Sjack Abeling Gravity Wheel and the Worlds first Weight Power Plant
Started by AquariuZ, April 03, 2009, 01:17:07 PM
Grimer
Thanks for that update on  SJack ABeling's gravity wheel.
I've always believed that SJack is harvesting higher derivatives of position with respect to time.
What's holding him up is an adequate understanding of where the energy is coming from, namely, earth reaction or Ft, force multiplied by time, 3rd derivative energy.
Who is she that cometh forth as the morning rising  -  Fair as the moon. Bright as the sun  -  Terrible as an army set in battle array.
Russ Lee
 "The working prototype is located somewhere else."? What? = Scam.
Quote from: AquariuZ on April 03, 2009, 01:17:07 PM
Greetings.
I was surprised to see a search on Abeling receiving "0" hits.
So, long overdue as he is about to go ballistic. (I think)
In November of 2007, an unknown dutch inventor made the rather outlandish claim he had found a way to rotate and accelerate a large wheel by using twin weights and earths gravity as only propulsion. At the time this was merely ruled a hoax.
See the dutch media (local) coverage here: Noord TV Report on Abeling device Edit: added Broli´s version with subs
After that it has been very quiet around Sjack, until a few months back he created a company Abeling Beheer B.V. and started a website which explains his intentions:
"The construction of the first Weight Power Plant is expected in May 2009. The location for the construction of the first Weight Power Plant is probably going to be the province of Groningen, the Netherlands."
and
"The Fall and Lift control system. The invention of the "Fall and Lift control system" was done towards the end of 2006. The system transports, controls and transmits mass/weight to (for instance) a drive shaft. This system was the foundation for a machine that can work on weights/mass only, without adding any form of energy. It's purpose is to drive other objects."
Abeling claims he now partners with reputable businesses like Henkel and has all the approvals needed to go ahead with the project.
Link to the bi-lingual webpage: http://mooieenergie.nl
He appears to be a cool customer, not at all media hungry, and has quietly filed his patents, raised capital and signed partner agreements.
Time will tell if he is 100% legit, his claim is that he will be able to provide power to the general public with at least a 50% discount against current regular provider rates. I think that still is too high, 95% would be better.
My questions to all in here are:
1) What do you think?
2) Have you heard anything about this?
3) If this is a "scam" why pursue it further now that he has all he needs?
My thoughts are that he truly has found a way to generate acceleration using weights and gravity only, or at least HE is 100% convinced.
I have sent him a message of encouragement, warning and a plea for full publication as soon as possible.
Cloxxki
http://www.mooieenergie.nl/category/news/
Dear reader,[/font][/color]
In the past few years it seemed quiet around our project. But we have certainly not been idle: We made another important discovery at the end of 2015. Thanks to this discovery it is now our objective to bring a functional system, powered by gravitation, to the market, possibly in 2016.[/font][/color]
With several unique transport systems masses are kept in balance and their centrifugal force is converted into potential gravitation; This is transformed into kinetic energy to drive, for example, a generator. The provided return is expected to be over 80% for driving secondary systems. On customer demand these can be low-, medium- or high-voltage, 50 or 60 Hz, 4 to 24 poles, and from 5 MW to 25 MW. Such generators are currently used in power plants and can be powered by the gravitational systems of Abeling Economy Group.[/font][/color]
Kind regards,[/font][/color]
De Abeling Economy Group...
Does anyone have fresh ideas? If the man doesn't back up his elaborate initial patent application with anything tangible, he looks to be yet another who thought to getsome millions from big corporates. Great liar, though, I'm Dutch myself.
I've also though there is some magic going on when you use gravity to gain an advantage. But I've only consiously found applications where it adds distance, never height. Examply, traveling in a straight line, perfectly level, on say an electric bicycle, no pedals, max speed, air drag limited. If a side road appears that lies lower, later to rejoin with the main road, you can use the gravity to speed up, win distance, and end up losing only part of that distance advantage when re-joining. This is especially true in system with high mass or low friction. In the case of near vacume, say a pre-Hyperloop system, going deep gets you across great distances really fast, with barely any energy input. Especially for the usual hard part : acceleration. 9.8m/s for every second you go vertical.
But how might Abeling exploits such a physics quirk?  You need to gain height, surely? Distance is not work, or can it be under some circumstances?
Through the work with Rodin coils, it seems to have been proven that electron flow more easily (less resitance) when spiraling (a cire) spiraling a certain way. Could Abeling have uncovered geometry for rolling weights to become lighter to be hurried along up higher? A combination of disconnect betweeen weight spin and travel curve?
I'm losing hope in Abeling though. Be may be like many, planning to take his findings to the grave, or go to the grave knowing that some still fell for his deceipt. If he wanted to go forward, he'd find better help.[/font][/color]
Thaelin
He like all the rest are trying hard in vain to hold out for the "millions" of dollars (or what ever currency) while the world squanders in poverty. Mankind for mankind is the only way it is going to work. That means full release to the world of a working device. When you have the comforts of life, what else is there? Do I need a Lexus? Hell no, that just feeds the ego and nothing more.
A gent here on the forum many years ago made the same statement, Centrifugal force is your friend, use it.  Natures best. Next is a good old lever. put those two together and you can move mountains.
thay
