Sjack Abeling Gravity Wheel and the Worlds first Weight Power Plant
Started by AquariuZ, April 03, 2009, 01:17:07 PM
hartiberlin
Quote from: AquariuZ on April 09, 2009, 06:12:04 AM
I have overlaid the barriers as I understand it from the video footage. Please check the screen shots I posted...
the red spheres represent the side view of the dumbbells. The green dot represents the extended axle which touches the barriers, the weights itself do not touch the barriers.
Now the KAD arms are a bit off and too short, but hopefully you will be able to see the path.
A) WEIGHT AXLE ENCOUNTERS LOWER BARRIER AT AROUND SIX O CLOCK FROM THE INSIDE
B) WEIGHT MOVES UP ALONG THE INSIDE OF THE LOWER BARRIER
C) WEIGHT PASSES LOWER BARRIER AND STAYS ALMOST MOTIONLESS FOR A MOMENT
D) THE WEIGHT MOVES RIGHT CAUSED BY THE MOMENTUM OF THE WHEEL
E) THE WEIGHT AXLE ENCOUNTERS THE UPPER BARRIER FROM THE OUTSIDE
F) WEIGHT MOVES UP ALONG THE UPPER BARRIER BY MOMENTUM
G) WEIGHT FINDS ITSELF IN THE SOCKET AGAIN AT 12:30, EXACTLY WHERE IT WAS AT 17:30
I hope you can now see what I mean...
AGAIN: SEVEN WEIGHTS ON THE LEFT - NINE ON THE RIGHT. HERE IS YOUR "D".
Hi AquariuZ ,
so you say, that this wheel does not work using centrifugal forces ?, cause
otherwise from 9 to 12 o´clock the weights would be pushed by the centrifugal forces
outwards to the rim and not going up your outer barrier in center...
Cherryman
Quote from: hartiberlin on April 09, 2009, 06:21:56 PM
Hi Cherryman,
the KAD7 file was only this.
Did you forget to post the file with the track-guides for the balls ?
By the way, what should the name KAD stand for ?
Did I miss this ?
Many thanks.
Regards, Stefan.
Strange, the arms should be there too, i will repost it.
This for me started as a little fun project with my daughter ( 8 ), we decided to built a "Top Secret free energie machine"  . It seemd as a perfect time to test the swingarm idear. We needed a "secret" name name and it become K. (first letter our name) Automatisch (Automatic)  Ding (Thing)
So see it with a blink  ;), but i have no choice   ;D
mondrasek
Quote from: hartiberlin on April 09, 2009, 06:10:11 PM
Hi Mondrasek,
without the motor driving the wheel,
this design is not selfrunning.
Here is a screenshot.
Regards, Stefan.
Stefan,
You are 100% correct.
As I said, this was "food for thought."  I did not want to distract the others completely from the directions they were already trying.
The file I posted has to do with a concept for extracting energy from the lower left quadrant of the cycle and reintroducing it at the upper left quadrant.  It was not intended as a working solution, just "food for thought."
Conventional physics shows that we cannot move a weight around a wheel and gain energy from gravity.  I don't see anything so far in this idea with just ramps and guides that changes that.  But I also am not saying it is impossible.  I am looking at the other "facts" stated by Abeling on his site and trying to get the rest of this "team" to starting thinking of how to gather energy in the lower left and use it to launch the weights in the upper left.  This was one idea.
Thanks,
M.
Cherryman
Quote from: mondrasek on April 09, 2009, 07:23:41 PM
Stefan,
Conventional physics shows that we cannot move a weight around a wheel and gain energy from gravity.  I don't see anything so far in this idea with ramps and guides that changes that.  But I also am not saying it is impossible.  I am looking at the other "facts" stated by Abeling on his site and trying to get the rest of this "team" to starting thinking of how to gather energy in the lower left and use it to launch the weights in the upper left.  This was one idea.
Thanks,
M.
Good! Keep them coming, i also post things i know dont't work , but i think that is the essence of this forum" Showing  progress and thinking, and  sharing. .
hartiberlin
Quote from: Cherryman on April 09, 2009, 06:58:24 PM
Still the guidance tracks for the weights are missing.
I only see the weights, the disc and the left ramp.
Which version of WM2D do you use ?
I have installed over here 5.1.2.53
Regards, Stefan.
