Sjack Abeling Gravity Wheel and the Worlds first Weight Power Plant
Started by AquariuZ, April 03, 2009, 01:17:07 PM
hartiberlin
Quote from: Omnibus on April 10, 2009, 11:20:33 AM
The disc is only 0.5kg and the steel balls are 0.1kg in the simulation. Where did you see the 1rad s^-1 motor?
I meant the simulation I modified, not the original KAD9.
This one attached to this message:
http://www.overunity.com/index.php?topic=7150.msg170088#msg170088
has a motor in it.
Check it out again.
Where is the one without the motor ?
Tracker
Hi Omnibus,
With all due respect.
There IS a motor in this simulation.
When removed, nothing happens.
If you have one without the motor, please post it here.
regards,
Tracker
Omnibus
Omnibus
Quote from: Tracker on April 10, 2009, 11:59:17 AM
Hi Omnibus,
regards,
Tracker
I just posted one for Stefan. In it I zeroed anything that I could lay hands on, except for gravity. One thing I noticed, though, values are seen here and there when I reset after rendering (not the torque and the rad/s). What else should I do to avoid "motor", do you think?
Tracker
Hi Omnibus,
It looks like you are RIGHT !!!
If I understood it correctly, in this specific case, the motor works only as "bearing".
Can be later use as generator.
Clever.
Let's try replace motor with some real bearing.
regards,
Tracker
Quote from: Omnibus on April 10, 2009, 12:01:04 PM
Stefan, try this one (attached).
