Sjack Abeling Gravity Wheel and the Worlds first Weight Power Plant
Started by AquariuZ, April 03, 2009, 01:17:07 PM
0 Members and 94 Guests are viewing this topic.
Grimer
Quote from: hartiberlin on April 10, 2009, 09:58:06 AM
Hi Grimer,
looks good, so it is a right turning cycle process, right ?
How can we make the area inside the curve bigger, for more output ?
Can you please calculate this and let us know, how to do this in the real world ?
Many thanks.
Regards, Stefan.
Thanks for your reply, Stefan. I must say I didn't really expect any. For one thing I thought the idea of an area on a displacement vs. time graph representing energy would too big a stumbling block. I can explain why it is energy but the explanation requires both an unconventional view of time, a view of stress as an alias for an equilibrium natural strain which leads to energy as strain energy.
I don't know what a "right turning cycle process" is I'm afraid. Perhaps Harvey's idea of a mini tide machine may be useful.
I know the area inside the loop looks a bit constrained but it better than Carnot and no-one has ever complained about that.
http://i136.photobucket.com/albums/q171/frank260332/Stefan1.jpg
From the sound of things I don't think one will need more power. Anyway, let's wait to see it actually working first before worrying about bells and whistles.
Who is she that cometh forth as the morning rising  -  Fair as the moon. Bright as the sun  -  Terrible as an army set in battle array.
mondrasek
Guys,
I think you are experiencing one of the (many) bugs in WM2D.  Try closing the program.  Then open the file and double click directly on the motor, or any other element to open the properties box.  Make sure from the pull down menu that you are looking at the Motor (Constraint 14).  It says the velocity is -1.0 rad/sec.  Change this to zero and nothing runs.
If you click around in the motor properties you will find that it stops working properly.  That is why you must start by opening the file and program from scratch and only look for the motor velocity.
Sorry,
M.
Tracker
Hi Mondrasek,
Just to be sure this is not WM2D problem, I'm reproducing this model in SketchyPhysics for Sketchup.
Let's see ...
Just in case I will not use any motor in this simulation.
regards,
Tracker
Quote from: mondrasek on April 10, 2009, 12:43:51 PM
Guys,
Sorry,
M.
itanimuLLi
Can anyone make a calculation and maybe an animation. the blue balls are static the reds are getting in and out of the rotor.
Omnibus
Guys,
Sorry,
M.
@mondrasek, I closed the program, opened it again, looked at V0 and its value was 0.000 rad/s. Then I ran it and, as usual, it started rendering it in a way that we already saw it does. Where's the problem?
