Sjack Abeling Gravity Wheel and the Worlds first Weight Power Plant
Started by AquariuZ, April 03, 2009, 01:17:07 PM
ramset
GRIMER
Seems you are not alone in your feeling
Chet
Noord TV Report on Abeling device
http://mooieenergie.nl
Thanks Grandma
Grimer
Quote from: ramset on April 05, 2009, 02:50:00 PM
GRIMER
Chet
Thanks for the link, very interesting - and as he says, it could have been discovered hundreds of years ago - but wasn't. Bit like my discovery of the equations of state for water vapour.
http://www.lsbu.ac.uk/water/strange.html
They could have been discovered early in the last century. All the data was freely available in the International Critical Tables but no one looked at it in the right way cos they where hogtied by erroneous theories.
Who is she that cometh forth as the morning rising  -  Fair as the moon. Bright as the sun  -  Terrible as an army set in battle array.
Grimer
Below are a couple of relevant paragraphs I've copied from
Iterative Hierarchical Mechanics N103/87
These equations may be interpreted as folows. Increase in the speed of an inertial body relative to its environment  (characterized by an environmental speed) is accompanied by a tranformation of the internal velocity, v, into an external velocity u. In other words the external kinestic energy is derived from the internal kinetic energy, or in simpler hierarchical terms, exteranl motion is derived from internal motion. Clearly this is a more mundane and intelligible explanation with the change in inertia with increasing speed than that normally given, an explanation moreover that is fully in accordance with the behaviour of a substance at a higher scale as exempified by the kinetic theory of heat.
In effect inertial substances are seen as active, not passive; as containing servo-mechanisms, force amplifiers. The energy put into accelerating a body is merely a control energy which is proportional to, but at non-relativistic speeds, a minute fraction of the total energy needed to overcome inertial effects. As the speed of the body reaches speeds comparable with the characteristic field speed the servo-mechanisms become less and less effective until at the speed of light all the energy has to be applied from external sources.
Cheeky? No 'alf. If true it tears the guts out of modern physics.
But a gravity mill will do that on its own.
infringer
all that I can say is if you take a look at this picture
http://mooieenergie.nl/images/stories/ab3.png
And you remember the sword of god and what we were trying to accomplish with the rods ...
This is the same exact pattern that Archer Quinn was trying to show us so if you believe this deal or if it comes true then Archer Quinn is not such a quack after all cause this was the design in which Dusty, redriderno22, and a few others were working on....
Done with just weights well... There you have it  it should work with the rods then as well or I would think a slight modification would provide the same results.
I'll stick to solar and wind power for now but keep pluggin away for those not interested in tried and true technology.
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
AquariuZ
Quote from: infringer on April 05, 2009, 09:32:43 PM
Not just weights, the pairs are part of an encapsulating system.
From the FAQ:
"The weights are applied two by two: one weight is pushing/falling, the other one has to be lifted. Due to the invention of the dual lifting system , the falling/pushing weight will hardly be hindered by the weight that has to be lifted.
In the top left of the system the weight is accelerated (like with shot put). The weight is moving faster than the system, and as the system catches the weight it is propelled forward. The path of the weights in the system is determined up front so the weights are always in a fixed position relative to each other and that will reduce the drag of the lifted weight on the falling/pushing weight. The system will start rotating from any position. Extra force is generated in the lower left of the system and on top it is transferred to the system itself, generating the extra energy. If the system would fail to catch the propelled weight, the weight would be ejected from the system with force."
