Sjack Abeling Gravity Wheel and the Worlds first Weight Power Plant
Started by AquariuZ, April 03, 2009, 01:17:07 PM
Dusty
Just another update.  I found some old plywood curve shapes and tried them on the wheel.  Like I say this is all guess work which will give me ideas to build the next test.  This video is just to show what I'm working on because once I make a big change it will be too late to see what I've tried.  If you see something I should try, just let me know.  The weight only needs to go 1 1/4" higher to reach the hockey stick slot.
http://www.youtube.com/watch?v=THC9mx7W1hg
Dusty
LarryC
Quote from: Dusty on April 18, 2009, 09:02:14 PM
Dusty
Very good Dusty,
But could you try to cut your guides closer to Eisenfickker2000's shape.
I also don't think your double pillows are a problem with friction. There friction ratio should be extremely low and a non issue. In fact, based on my testing, they should reduce any warping pressure that would result in much higher friction.
Regards, Larry
Philip Hardcastle
Anyone here remember Dr. Eugene Podkletnov?
He reported that a spinning superconductor disc would reduce gravity by a few percent.
Not wishing to throw in a red herring it does seem to me that if he were right then one side of the wheel could get 10% less gravity and perhaps somehow the other side get 10% more gravity.
Whatever happend to Eugene.
He actually rang me from Finland when I suggested there could be a reason for the effect based upon differential electrostatics. He was most interested that I predicted certain phenomena with a theory that said gravity might not be just about mass to mass attraction.
Phil
Philip Hardcastle
He asked me to talk to some italian mathematician (modonese or something) but I did not.
I cannot recall but I think the Italian professor published a paper trying to explain the effect and how it would fit in with conservation of energy. I guess (and I have not read the paper) he must have suggested energy came from the universe in the direction of the gravity reduction.
Perhaps someone might dig and find more.
I however still hold the view that a simple lever etc wheel will not work, so I feel perhaps we should think outside the circle, so to speak.
Phil
Philip Hardcastle
I found this article about gravity and some experiments to show gravity might be modified.
http://www.newscientist.com/article/mg19225771.800
Also Eugene Podkletnov is on wikipedia
