finally a free energy from convergence of all type of incame......
Started by hammuraby, April 11, 2009, 12:15:39 PM
hammuraby
hallo, here is a person that have made a motor PPath as the FLYNN, whit a pure efficience close to 95%, and at the same the generator....
but, this engine is new, and hand made from meccanich-man....
BUT in a open circle that include a Braiton cicle, whit only a 30C° of thermich DELTA this is selfrunning....
the best solution is this because.....is possible to use rain, cold, hot-sun , or elettric generation,
for refill the accumulation pool,....ALL in ONE system for convergence then give energy....
1)whit cold winter air in compression, and a geothermic in exit , you have a heat for free, an also a little production
2)whit hot air in summer, descharge a compression heat in water, the expansion give a cooling free, after use a sun termic...for going in free energy
3) you can put inside a cicle a DC from fhotovoltaic , and came out AC
give at free the climatization service, and give also free energy from convergence of all RENOWABLE , my be this will store energy using a pump , and give energy from water send to bottom of sink ....Water...
did you remember a CoralCastle reveled ?? powered from rain....
good will , from ITALY , we are close to became a selfpowered nation...you too??
i can give all explication....
Cap-Z-ro
This sounds interesting Hammuraby...do you have any schematics or information on the device ?
Regards...
hammuraby
hi, for now i haven't a picture, but i will done soon is possible...
the start is around tree tech:
1) a parallel path engine (DC from fhotovoltaic solar) or AC from grid....
http://www.youtube.com/watch?v=nu55AfLbWU0
2) a external fired gas turbine, or brayton cicle (cold air into compression, heat into expansion)
http://www.fms.uni-rostock.de/ieut/Lisbon_Paper_Kautz.pdf
3)micro grid "island" based on  the accumulation of energy ,(collector of surface rain-water)
as this: http://www.overunity.com/index.php?topic=6911.0;topicseen
whit the BASE of HI efficence of deviation magnetic engine (95%) and generation,
this can be used whit a brayton cycle, and this can became in free energy soon...
in winter cold air is --C° and geothermic +C°
in summer little heat air +C° and solar heat ++++C°
can done all year long the same DELTA thermic...
at the end of the cicle a water accumulator whit the pool in surface of a sink.....
then is possible to put into the system, that convert ALL source of energy into WATER STORAGE...
basicly: haet-sun,biomass combustion,  cold air , elettricity, and rain....but also a sea wave energy, or wind...
picture soon....and a help frm YOU, will be wellcame
hammuraby
the picture dont have a size , for post on this ...
but whit a HI efficence cicle from engine -generator , whit a infinite natural heat incame on mode as Brayton , we will have alltime a free energy; but also a climatization service at free,
as underproduct
http://picasaweb.google.com/s.galli1966/EverywereUrbanSystem?feat=directlink
hammuraby
i am sure that NONE have take a look at the picture up placed; because, this is not a simple device, but a system that can give energy for free, taking a by turning low termich in energy ...
i wish that some one start the discussion about, don't miss the appointment whit a reality...
and give a hand on a world wide overunity alltime working
URBAN (for village african or Nkorea) SYSTEM
