Does a proven working TPU device exist at this time?
Started by AquariuZ, April 17, 2009, 08:47:22 AM
Bruce_TPU
Evening Loner,
Another experiment, similar to what I described in my last post, is the following experiment from SM.
Take two transformers, and connect them in REVERSE POLARITY to one another.  Simply split the same AC Sine Wave Low Voltage signal, same source and shoot it across.  Add pulsed HV DC for fun.  Use your SA or Scope, and see what you see when the multiple frequencies "combine" (Cancel)  Same idea as the inverted phase, but is using reversed polarity to create the same effect.   ;)
EDIT:
Oops!  Almost forgot to mention, that the Transformer used must match with the AC voltage used (resonance).  Example:  SM uses 5 volt AC transformers, signal split is 5 volt AC, transformers wired in reverse polarity to produce "cancellation" combining.
Cheers,
Bruce
Bruce_TPU
Quote from: Loner on May 26, 2009, 04:04:42 PM
Interesting, and actually, in process.
I must mention, however, that two transformers connected in such a manner, when looked at from a distance, seems far to close to another circuit that causes much "disagreement" among various people.  I'm staying out of this fray, as I can only process and understand so much, and at my slow rate, this takes a LONG time, but just to confuse those that miss the evidence, think about the VIC Ckt, from input to output, including the "Coils" on the output and their proximity to each other for mutual inductive effect.  (If you recognise this reference, you will see it, and if not, then I can't be of any help.)
(Little note:  Normal PC PS Switching transformers work well in this application, but I am not making any recomendations....)
I have found that certain of these "Effects" can be produced in a single loop TPU, with only two frequencies, but until I understand the real "How" this is working, I'm not ready to make more of a fool of myself.
Thanks for the info, as I'm finally starting to grasp the real import of this stuff, regardless of the project.  This knowledge may never produce anything but my own satisfaction, but you never know.....
I just hope to be able to actually put forth a real design that is reproduceable and testable by all, someday.  I hear many claims, but still don't see real physical devices, so I can assume the true basis is still not fully defined.  With me lurking here, picking the brains of all the people who have info, maybe I can get lucky.  At least my original copper cored, single loop device can get more use as my basic "Reference" as I've fed more signals into that than I care to mention.  Seems strange that a Bifilar wind on the outermost layer, with opposing flows, does seem to have a different effect than expected.  (Call it a field witout a field?)  Pushing misc signals (Like yours...) into the inner coils, and producing "Noise" has drastically different results, depending on the outer field, which "Doesn't exist" because of the cancellation effect of the Bifilar wind.  Makes no sense, YET.....
Just typing that confused me, so I can see I need to read more, test more, and type less.
Thanks to everyone.
Hi Loner,
Common-mode current = radiant emissions
Positive bias = harvesting (collecting) said radiant emissions
