The ever elusive magnetic motor
Started by billmehess, April 22, 2009, 10:49:31 PM
ramset
yes I have seen this
http://keelynet.com/gravity/bedham1.htm
Not what I saw !!
OK
I see this is looking alot harder than it is.
Mental picture,
take a frisby lay it on a piece of 1/4 inch plywood
trace the outline of the frisby  adding 3/8 of an inch all the way around
cut out the hole put the frisby back in the hole you should have 3/8 gap all the way around
Take a roll of pennies put them all around the outside edge of the frisby, flat on the top outside edge then put them all around the hole[flat on the top edge closest to the frisby]replace pennies with mags  put them allnorth on the frisby allsouth in the hole
YOU HAVE SUSPENTION IN ATTRACTION[NOT REPULSION}
Of course the frisbee should be wood [so you can draw laytout lines from one side to the other so you know your mags are balanced]and the mags I saw were1/2 inch round by 1/2 inch tall cylinders
just for clarity you could flip this disc upside down and sideways and not remove the disc from the hole .
He said it would hold the weight of a person!![right side up or upside down]
I suppose I'll replicate and share
Chet
PS
I suppose I'm just curious if this closed loop[trapped in attraction] hovering field will have properties that allow it to be spun with out gates/cogging?
PPS
is this the road to magnets shielding themselves ?[something I was told was possible]
Ply- N MAG 3/8 spaceS Mag   d    i    s   k  S mag 3/8   N mag
PLY N MAG                S MAG    Disk         S MAG          N MAG  PLYwood
                               THIS DISC FLOATS IN
                                 ATTRACTION
Thanks Grandma
billmehess
If the top disk is spun it will rotate very unstable and it will stop quickly. There is no cog or gate in the configuration. I can see where you are trying to go with this but if you introduce an external stator assembly the standard coging issue will rear it's ugly head.
ramset
BILL
Its not a top disc
All mags were on the same plane  ===  === FLAT
Chet
Thanks Grandma
billmehess
I understand , but again I suspect it's a Hammel spinner principal.
0c
Quote from: ramset on June 19, 2009, 12:48:17 PM
BILL
Its not a top disc
Chet
Something is missing in your description. Next time you go for a visit, find out what. Better yet, take your camera and post some photos. Is there a patent description?
Thanx
