Thanks to ALL for your help!!
Cold Electricity
Started by gravityblock, April 30, 2009, 01:11:26 AM
turbo
Your above post sounds a little bit like Tom Bearden to me.
Quote from: gravityblock on April 30, 2009, 09:11:14 PM
Tesla's wireless transmission of electricity is transmitting photons and not electrons.
Can you please explain how you came to this conclusion?
Marco.
hansvonlieven
Can someone tell me how many kinds of photons there are.
We know of the visible kind and then we know of some of the invisible ones like ultra-violet and infra-red.
How many others are there?  ??? ??? ???
Hans von Lieven
gravityblock
Quote from: hansvonlieven on May 01, 2009, 04:04:23 AM
Hans von Lieven
Only one kind of photon.  The photon makes up the entire electromagnetic spectrum from radio waves to gamma rays.  Photons are delivered in packets or quanta.  Higher frequency photons can be delivered faster than lower frequency photons.  The higher frequency photons travel the same distance as lower frequency photons in a given amount of time, but they travel more space in the same amount of given time.  This is due to their wavelength.
Try to visualize a photon propagating through space in a corkscrew motion.  The shorter wavelengths will have a tighter corkscrew motion and is making more turns per revolutions than the longer wavelength photons, thus traveling the same distance but traveling more space in a given amount of time than a longer wavelength photon.
A photon that propagates through space in a straight line instead of a corkscrew motion would have a near zero wavelength and could be delivered in a continuous stream instead of packets, thus traveling faster than the speed of light.  In my opinion, this is the virtual photons and virtual particles that physics theorize about.
Try to think of a led light blinking.  The slower it blinks, the longer the wavelength is. This would represent a photon with a longer wavelength.  The faster it blinks, the shorter the wavelength is.  If the light is continuously on with no blinking, then it would have a zero to near zero wavelength and this would represent the virtual photon that physics theorize for the magnetic field of flux.
This is the reason why the magnetic field of flux is not changing in a magnet (the virtual photons are being delivered in a continuous stream and cutting the flow of electrons), thus we have to move the magnet or conductor in order to cause electrons to flow along a conductor.
If the virtual photons were delivered in packets in the magnetic field of flux, then we would have a changing magnetic field of flux and wouldn't need to move the magnet or conductor for electron flow and would have OU very easily.
It appears to me that the entire universe is a sea of these virtual particles, which I say is the aether.
Most of this is currently accepted in physics as being correct, but some of this is my own personal theory.
What do you think about this theory of mine?
gravityblock
Quote from: -[marco]- on May 01, 2009, 03:51:09 AM
Marco.
If I tell you how I came to this conclusion, you wouldn't believe me.  Let's just say it is a feeling that I have and not a fact.
The popular Tesla coils that are well known are the direct result of the apparatus perfected by Sir Oliver Lodge and not by Nikola Tesla.
Lodge Coils are alternators. Tesla Transformers are unidirectional impulses. Tesla Transformers are not magneto electric devices, they use radiant shock waves, and produce pure voltage without current.  No current means no electron flow.
The reason for no current, is because the electrons and positrons annihilate each other due to using both the negative and forward time of space, and this would give off huge amounts of high energy photons that would be transmitted through space to a receiver box.  The process that gave off the huge amount of photons is cold electricity or radiant energy, but the current that would flow from the receiver box would be normal electricity.
The cold electricity that I am referring to would only use the negative time flow of virtual photons or space, from the magnetic field of flux to produce a negative time flow of electrons along a conductor, instead of producing forward time flow of photons that would propagate through space as in Tesla's setup.
You will have more questions than I have answers for.
turbo
Quote from: gravityblock on May 01, 2009, 06:31:14 AM
My question was related to wireless power transfer and photons.
Now you are talking about Tesla coils...Those two are diffrent things.
The reason for no current, is because the electrons and positrons annihilate each other, and this would give off huge amounts of high energy photons that would be transmitted through space to a receiver box.  The process that gave off the huge amount of photons is cold electricity or radiant energy, but the current that would flow from the receiver box would be normal electricity.
Tesla's Wireless system did not transmit anything through space to a receiver box, Tesla used earth as the hot terminal.
The energy was propagated through earth itself.
If you read Eric P. Dollard's book "Theory of wireless power"
He explains very well how Tesla's system operated.
The tower was simply a weight to push against, a "virtual ground" in order for the system to become self referencing.
Marco.
