High volume gas production at 12,6 Volts and 10mA !
Started by hartiberlin, February 15, 2006, 06:38:46 PM
hartiberlin
Elvis Oswald
This looks promising... but what kind of production would you have to achieve - say using the cell directly in a car with the battery and generator as the source - to duplicate the power output of the same motor running on gasoline?
That's the $$ quesiton.
What are the added costs associated with capturing, pressurizing, and delivering the fuel to combustion?
I just can't get excited about burning fuel to produce energy.   :-\
BushWacker
Hi Group,
    Does anyone know of a precise frequency range which has been used to create flash hydrogen? By the term "Flash Hydrogen" I am refering to an immediate conversion of H2O to its base molecules eg; hydrogen and oxygen by means of molecular breakdown. You may be familiar with the term and if so are more likely to understand my question and the reason for asking for this precise frequency range. The reason for my interest is that I am wondering if it might be possible to tailor a HOPE Generator to operate at this frequency range. If the proper resonant frequencies could be applied using the HOPE approach it would be very interesting to test this theory and I believe that it might be possible to create hydrogen in large volumes using very little actual power to do this. Any input is much appreciated guys.
Best Regards All,
Jim
Magick
Hi Jim
Stan Myers was using, if I recall correctly, 21000hrz to fracture water - at .5amp.
Liberty
Quote from: BushWacker on March 08, 2006, 01:57:12 AM
Hi Group,
Best Regards All,
Jim
It is my understanding that a microwave oven works on the idea that about 2.4 ghz is the frequency that water resonates at.  A microwave vibrates the water molecules and that creates friction, and heat results.  The heat generated by water molecule friction heats/cooks the food.  May also break down water?
Liberty
