Thanks to ALL for your help!!
Sonic Resonator Results and Findings, As Well As LTspice Models To Download
Started by D.R.Jackson, May 08, 2009, 07:52:27 PM
Bruce_TPU
Dear D.R. Jackson,
TinselKoala, who others on this forum used to know as "Al" is a skeptic of anything O.U. and a Hoaxer.  Please do not let him dissuade you or bother you too much.
Keep up the good work!
Kind regards,
Bruce
D.R.Jackson
Quote from: Bruce_TPU on May 09, 2009, 04:43:32 PM
Dear D.R. Jackson,
Kind regards,
Bruce
I read their other comments in my other post and concluded that all of their preoccupation over significant figures concluded that they were a nut.
I will not be dissuaded.
I have one more comment to post about this individual.
Thank You
D.R. Jackson
D.R.Jackson
P.S.
I was sure that someone would come along who would not be satisfied with a square wave with a little ripple, and maybe a so slight deviation in the base width of the wave compared to the top width of the wave.
I knew that someone like that would come along.  However, those who have been in electronics a long time, know enough to know that slight deviations do not stop the circuit from performing to close enough specifications such that we would never dream of building and testing and hopefully perfect a test bench model. Etc. etc.
And as to your comments in my other post about this device and the amount of significant figures that the software computes to power to be, up to 5, 6 or seven figures past the decimal point.  In practise we usually just round those off to three figures.  Maybe two significant figures past the decimal.  And as to why someone wants to be so precise in measuring every little figure down to 5, 6 of 7 figures past the decimal, well you can do that if you want.  But most of the time we do not.
One thing you did not comment on, was the unusual fact about the period of the power half cycle being increased to 0.64 wave cycles (to 230 degrees).  So how do you account for that and the power in that extra 14% of added period?  Can't explain that can you?
Anyways such comments as those made about these matters will not deter anyone who sees what is up; from want to examine this all the more.
And if the individual thinks that we have the time to answer such trivial questions about minute details about imperfections of wave form and about a string of significant figures past the decimal.  Well as for such trivial things, no one has the time to waste to pay attention to such an individual.  So post such trivial comments all you want.  The sum of them, does not out weigh the sum of the findings of this circuit that everyone can analyze.
After having read more of you comments at my other post, I thought I would tell people what you are up to.  And so, enjoy yourself all you want.  We will keep up our work and stay on course, despite you.
fritz
Well,
Spice is a nice tool -
BUT
You need to understand a little bit more to use it.
I would start to _READ_ about the difference between Energy and Power. Thats essential for further investigation.
Its _NO_ OU to make a pulse with higher power out of a powersupply with less power.
Take a photo flash - during charging it takes few watts for some seconds to charge - and can release it with the power of more than 100 watts.
Your circuit increases the power and not the energy.
I can make a 1MW pulse out of a 1W source - if i charge the 1W source for a million of seconds I got the energy of 1MWs - I can discharge that for 1s and get a 1MW impulse.
The energy you got is your 8.xxW times the dutycycle - thats 0.64 - so its slightly less than your input cycle.
Your output voltage is not rectangular - its pulsed dc - so the rms value is as above.
The "rms"=="peak" only applies on _TRUE_ AC.
Having great tools like spice doesn´t compensate the basic understanding of electricity.
Paul-R
Quote from: D.R.Jackson on May 09, 2009, 04:59:51 PM
Thank You
D.R. Jackson
There a few others also.
Paul.
