Thane Heins Perepiteia Replications
Started by hartiberlin, May 28, 2009, 05:54:52 PM
baroutologos
Perhaps i did not epress myself good :)
I did not meant to parallel wound two coils on same core and series connecting them. (unless you meant two idependent coils, bifiilar parallel wound-series connected and then again series connecting the two of them also)
I meant what is your experience in connecting 2 independent coils, physicaly spaced apart and connecting them in a series mode and having same phase. Does the accelararion effect stacks?
"LONG" CORE
22 GAUGE WIRE @ 35 OHMS EACH
SERIES WOUND BI-FILAR
CONNECTED IN SRIES
perhaps you meant parallel wound, series connected?
Magnetic closed circuit
Instead of coil's ends being in open air, having them arranged in a closed magnetic circuit boosts the effect. Is this make, really such a great diference?
Regards,
Baroutologos
minde4000
@Thane
At what angles are 2 of your coils positioned on toroid? Are they directly one above rotor one of the south another one of the north poles or one is @2.5 and another @45 or what degree?
Finally found some glue (that works) for my rotor magnets (gorilla epoxy) after wasting a week trying other brands. Cure in progress. JB Weld is the best but you cant apply it to the middle of the magnet because it contains ferrite particles and glue gets sucked towards both ends instantly leaving dry middle portion ;D Getting automatic coil winding machine also but now when bifilar coils turned out to be the case not sure if it is going to be of any use... or any machine can do bifilars too?   :-\ Rotor getting magnets glued have a toroidal ring ryobi but no coil mounting laminates yet..
Thanks for all info
Regards Minde
CRANKYpants
Quote from: baroutologos on June 19, 2009, 09:12:59 AM
YES IT DOES
Quote............................................................
Regards,
Baroutologos
HAVING A CLOSED MAGNETIC CIRCUIT ALLOWS MORE ROTOR FLUX TO PASS THROUGH THE COILS - SO THE OUTPUT IS GREATER.
QuoteLONG" CORE
CONNECTED IN SRIES
YES - I WAS ON CRACK THIS MORNING SORRY.
T
CRANKYpants
Quote from: minde4000 on June 19, 2009, 09:48:51 AM
@Thane
GOOD QUESTION - THEY ARE DIRECTLY ABOVE THE MAGNETS SO THE COGGING TORQUE IS HIGHER THAN NORMAL - BUT I GAVE UP ON TRYING TO MININIZE COGGING TORQUE WITH HAND MADE STATOR CORES.
QuoteFinally found some glue (that works) for my rotor magnets (gorilla epoxy) after wasting a week trying other brands. Cure in progress. JB Weld is the best but you cant apply it to the middle of the magnet because it contains ferrite particles and glue gets sucked towards both ends instantly leaving dry middle portion ;D Getting automatic coil winding machine also but now when bifilar coils turned out to be the case not sure if it is going to be of any use... or any machine can do bifilars too?   :-\ Rotor getting magnets glued have a toroidal ring ryobi but no coil mounting laminates yet..
Thanks for all info
Regards Minde
MY WINDING MACHINE IS A DC MOTOR w/ A DC POWER SUPPLY THAT I CAN ADJUST AND I USE TWO SPOOLS OF WIRE WHICH I WIND SIMULTANEOUSLY - I HOPE THIS WILL WORK ON YOUR MACHINE - IF ALL ELSE FAILS TRY A HAND DRILL.
GOOD LUCK
T
CRANKYpants
LC AND ALL,
I CANNOT RESPOND TO PM's FOR SOME STRANGE REASON?
SO IF YOU WANT TO PM ME, PLEASE DO IT THE OLD FASHIONED WAY VIA EMAIL @
thane_heins@yahoo.ca
THANKS
T
