New TPU build
Started by Farrah Day, June 14, 2009, 07:13:39 AM
tsl
Quote from: Yucca on June 26, 2009, 03:30:30 PM
Some improvements are needed, like using a core material capable of much higher freq and so higher virtual RPM.
what about air as a core?there is a solution also for dealing with the fields that would be not contained and that's related to the topic here. :P
BEP
Quote from: Farrah Day on June 27, 2009, 11:31:20 AM
You may well suggest it BEP, but magnetic fields would seem to be one of the only things we can be sure are interacting. Out of curiousity what do you suggest I replace 'magnetic' with?
It is my strong belief that all fields, including temporal, are different perspectives of the same thing. Electric and magnetic are commonly thought of as the same thing as viewed from different frames.
The biggest mistake I see folks making is saying they are working with the magnetic and only measuring the electric. Are they assuming what is going on with the magnetic?
If you wish to stick with magnetic only then consider measuring the magnetic only.
Regardless, I can assure you this is not a 2D universe.
Yucca
Quote from: tsl on June 27, 2009, 11:37:32 AM
Air core is VERY easy to saturate and handles very high freq, agreed, but maybe too easy, in air core you will get mostly EM radiation. I think maybe the answer is a subtle blend of inductive and EM action, that's why I plan to build a core that can be saturated so a mix of inductive and EM action can be combined. When you saturate a metalic core you will then overflow into the surrounding aircore. I have a feeling both are needed. That's why the core I will experiment with will be metglass and thin paper (masking tape) laminations. The paper will be pretty close to aircore.
p.s. what does the tongue sticky out smilie mean  :P? Call me thick but I've never worked that one out? byeeee!
BEP
I think in the earliest TPUs it was an attempt to reverse transformer function.
The core was copper and the windings were iron. If you could get the magnetic to flow similar to electric current you could create the correct mag field around the core/wire loop just as if you put a current in that wire loop.
Wouldn't that form also cause an anti-Lenz result?
Face it.... The universe is reciprocal.
Yucca
love ya ist. see you on the other side bro!
