New TPU build
Started by Farrah Day, June 14, 2009, 07:13:39 AM
BEP
The Mobius loop, in this case, has two qualities.
1. The current flow has one direction.
2. The coil polarity flips between the top and bottom loop sections. (WRONG! in the way it has been shown used for most TPU builds. The polarity does not flip in these builds but it may allow acceleration on one half of the loop only, while causing 720 deg. rotation to complete a circle.)
For the 'Norbert' comment I suggest you do experiments about static magnetic fields with velocity, while in the Earth's field. I know of no papers on this.
Edit>>>
Oops! 'Static magnetic fields with velocity while in another magnetic field'. I made a Sideroxylon  :D
Farrah Day
Nope, I just can't see how a coil of wire can be turned into a Mobius loop, especially given there must be terminals for the load.
Are there any drawings or depictions of a collector coil laid out in Mobius loop format, because after playing about with a piece of string for half an hour, I'm really struggling to see how this can be be achieved.
A Mobius strip, band or ribbon is very clear to understand, but applying this to a coil of wire is not at all obvious, and I have my doubts about this being incorporated in an SM TPU.
Farrah Day
"It's what you learn after you know it all that counts"
Mk1
@all
http://jnaudin.free.fr/html/tripole.htm
this can also be done from a bifilar coil and without the knots , so can't assume that sm did not use it . but if it really doesn't see its load , then i doesn't mess up the kick sync.
Mark
BEP
Quote from: Farrah Day on June 20, 2009, 10:47:40 AM
Try it with a piece of ribbon cable (multi-conductor flat). It'll be easier to visualize but not likely part of a TPU.
I don't remember 'Mobius' being mentioned in the SM texts anyway. It just seems to provide positive results for a few who have tried it.
The key is 'always do it the way you understand it'. Make your own choices.
Who said this coil is where load is connected? That would defeat the purpose.
See..... I think of things my way  ;D
MACEDONIA CD
heloo  here
i like to say some simple my thinging
if i say  that for ufos  and tpu there is clousing stuff beatveing this two
everthing is magnetism  and rotations
some my of  hmm
for ufo  craft
< if the  flaying disc or craft or  ... is posible to make  insaid to have some  mexanical  devics or not mexnical  spinig  ho whill be  more fast then 82 meter in one secund to makes rotation then  the  objeckt whill be  very easy to move beacouse  he whill be lost the kilogram or tones
>this  whill be produced own antigravitation  >
tpu is like that   like giroscope effeckt > s.m say  that in his vedeos
is makes  spining vortex
