Modernized Ark of the Covenant with 2 Tesla coils!
Started by gravityblock, June 20, 2009, 05:32:42 PM
gravityblock
Here is the link for the modernized version proposed by Hutchison using 2 Tesla coils, which is based upon the instructions found in the bible.
http://www.hutchisoneffect.ca/Ark%20Of%20The%20Covenant%20II.html
In Exodus 25:10 after the Hebrews had left Egypt God gave instructions to Moses regarding the building of the Ark:
........Have them make a chest of acacia wood - two and a half cubits long, a cubit and a half wide, and a cubit and a half high. Overlay it with pure gold, both inside and out, and make a gold molding around it. Cast four gold rings for it and fasten them to its four feet, with two rings on one side and two rings on the other. Then make poles of acacia wood and overlay them with gold. Insert the poles into the rings on the sides of the chest to carry it. The poles are to remain in the rings of the ark; they are not to be removed.
Make an atonement cover of pure gold - two and a half cubits long and a cubit and a half wide. And make two cherubim out of hammered gold at the ends of the cover. Make one cherub on one and the second cherub on the other; make the cherubim of one piece with the cover, at the two ends. The cherubim are to have their wings spread upward, overshadowing the cover with them. The cherubim are to face each other, looking toward the cover.
There above the cover between the two cherubim that are over the ark of the Testimony, I will meet with you and give you all my commands for the Israelites.....................
onthecuttingedge2005
It is a leyden Jar by definition and the wing tip to wing tip gap is the frequency & wavelength. I figured this out 20 years ago. the "poles" to lift up work on the frequency & wavelength, this stuff has been easy, almost second nature. if this is all that has been figured out then I feel a little better about myself, as a drunkard and both a saint and an atheist. have you figured out what the pillars of the temple are and whose name is on one? I can tell you they are not Tesla Coils and I have a diagram on how all seven work.
Jerry
Hi Jerry
The temple pillars are VDG machines or a close analog. They spin in the desert wind, or are scraped by the blowing desert sands, and collect the charge that is then stored in the Ark. The heavy leather shields and curtains, the darkness in the temple (to accentuate the corona glow) and the heavy incense smoke all are features of this electrostatic powerplant.
The two pillars on either side of the entrance are named Boaz and Joachim. The other five that you mention are news to me--I don't know of them.
gravityblock
Quote from: onthecuttingedge2005 on June 20, 2009, 08:35:44 PM
Jerry
Jerry,
When you have time, could you post the diagram on how all seven works.
You are correct in that the original Ark of the Covenant is not using Tesla coils.  The modernized version is integrating the technology of today with the technology of yesterday in order to keep the costs and time requirements down to a minimum.
How much money and time do you think it would cost to overlay the inside and outside in pure gold with 4 gold rings, 2 gold poles, a gold atonement cover, and 2 gold cherubims?  In addition to the costs, the time requirements to build would be huge for a person working from his garage.  This is the reason for the Tesla coils I suspect, to keep the costs and time requirements lower for the building process.
To be honest with you, I haven't spent a lot of time analyzing or studying these ancient technologies.  Maybe this will be a beginning of a new adventure for me.  Who knows, there is too much for a person too even consider in a lifetime.
Thanks,
GB
"The day you stop learning, is the day you die"
Okay before I do that let me share something with you:
Ge:15:17: And it came to pass, that, when the sun went down, and it was dark, behold a smoking furnace, and a burning lamp that passed between those pieces.
Ex:25:37: And thou shalt make the seven lamps thereof: and they shall light the lamps thereof, that they may give light over against it.
Ex:27:20: And thou shalt command the children of Israel, that they bring thee pure oil olive beaten for the light, to cause the lamp to burn always.
Ex:30:7: And Aaron shall burn thereon sweet incense every morning: when he dresseth the lamps, he shall burn incense upon it.
Ex:30:8: And when Aaron lighteth the lamps at even, he shall burn incense upon it, a perpetual incense before the LORD throughout your generations.
Ex:35:14: The candlestick also for the light, and his furniture, and his lamps, with the oil for the light,
Ex:37:23: And he made his seven lamps, and his snuffers, and his snuffdishes, of pure gold.
Ex:39:37: The pure candlestick, with the lamps thereof, even with the lamps to be set in order, and all the vessels thereof, and the oil for light,
Ex:40:4: And thou shalt bring in the table, and set in order the things that are to be set in order upon it; and thou shalt bring in the candlestick, and light the lamps thereof.
Ex:40:25: And he lighted the lamps before the LORD; as the LORD commanded Moses.
Le:24:2: Command the children of Israel, that they bring unto thee pure oil olive beaten for the light, to cause the lamps to burn continually.
Le:24:4: He shall order the lamps upon the pure candlestick before the LORD continually.
Nu:4:9: And they shall take a cloth of blue, and cover the candlestick of the light, and his lamps, and his tongs, and his snuffdishes, and all the oil vessels thereof, wherewith they minister unto it:
Nu:8:2: Speak unto Aaron, and say unto him, When thou lightest the lamps, the seven lamps shall give light over against the candlestick.
Nu:8:3: And Aaron did so; he lighted the lamps thereof over against the candlestick, as the LORD commanded Moses.
J'g:7:16: And he divided the three hundred men into three companies, and he put a trumpet in every man's hand, with empty pitchers, and lamps within the pitchers.
J'g:7:20: And the three companies blew the trumpets, and brake the pitchers, and held the lamps in their left hands, and the trumpets in their right hands to blow withal: and they cried, The sword of the LORD, and of Gideon.
1Sa:3:3: And ere the lamp of God went out in the temple of the LORD, where the ark of God was, and Samuel was laid down to sleep;
2Sa:22:29: For thou art my lamp, O LORD: and the LORD will lighten my darkness.
1Ki:7:49: And the candlesticks of pure gold, five on the right side, and five on the left, before the oracle, with the flowers, and the lamps, and the tongs of gold,
1Ki:15:4: Nevertheless for David's sake did the LORD his God give him a lamp in Jerusalem, to set up his son after him, and to establish Jerusalem:
1Ch:28:15: Even the weight for the candlesticks of gold, and for their lamps of gold, by weight for every candlestick, and for the lamps thereof: and for the candlesticks of silver by weight, both for the candlestick, and also for the lamps thereof, according to the use of every candlestick.
2Ch:4:20: Moreover the candlesticks with their lamps, that they should burn after the manner before the oracle, of pure gold;
2Ch:4:21: And the flowers, and the lamps, and the tongs, made he of gold, and that perfect gold;
2Ch:13:11: And they burn unto the LORD every morning and every evening burnt sacrifices and sweet incense: the shewbread also set they in order upon the pure table; and the candlestick of gold with the lamps thereof, to burn every evening: for we keep the charge of the LORD our God; but ye have forsaken him.
2Ch:29:7: Also they have shut up the doors of the porch, and put out the lamps, and have not burned incense nor offered burnt offerings in the holy place unto the God of Israel.
Job:12:5: He that is ready to slip with his feet is as a lamp despised in the thought of him that is at ease.
Job:41:19: Out of his mouth go burning lamps, and sparks of fire leap out.
Psalms:119:105: Thy word is a lamp unto my feet, and a light unto my path.
Psalms:132:17: There will I make the horn of David to bud: I have ordained a lamp for mine anointed.
Proverb:6:23: For the commandment is a lamp; and the law is light; and reproofs of instruction are the way of life:
Proverb:13:9: The light of the righteous rejoiceth: but the lamp of the wicked shall be put out.
Proverb:20:20: Whoso curseth his father or his mother, his lamp shall be put out in obscure darkness.
Isa:62:1: For Zion's sake will I not hold my peace, and for Jerusalem's sake I will not rest, until the righteousness thereof go forth as brightness, and the salvation thereof as a lamp that burneth.
Eze:1:13: As for the likeness of the living creatures, their appearance was like burning coals of fire, and like the appearance of lamps: it went up and down among the living creatures; and the fire was bright, and out of the fire went forth lightning.
Da:10:6: His body also was like the beryl, and his face as the appearance of lightning, and his eyes as lamps of fire, and his arms and his feet like in colour to polished brass, and the voice of his words like the voice of a multitude.
Zec:4:2: And said unto me, What seest thou?  And I said, I have looked, and behold a candlestick all of gold, with a bowl upon the top of it, and his seven lamps thereon, and seven pipes to the seven lamps, which are upon the top thereof:
I mean it is rather simple and this is just the Old Test, by reading this you should be able to tell me what it is and a Van De Graaff isn't it but it was a really good stab. even TK should be able to tell you what Lamb in the new Test means in scientific terminology because I know for a fact TK is a really exceptional mind in my reference.
From my mouth and only my mouth and not what you see in the words in your mind but mine only, the seven pillars are the seven candle sticks and the seven candle sticks are the seven virgins the seven virgins are also the seven churches, I could continue this but I don't think I have to..
if you nail it then I will share my version of the Seven Pillars as scientific art work and I will reveal its workings. please don't hack my machine, it will do you no good because it contains no valued information of what everything is and I would consider this cheating yourself out of a good experience and I will not share it if someone tries to steal it.
for the pillars are not the only one.. one needs to know.
is this to much? a mystery, I hope not. please allow it. thank you.
Basic Instructions Before Leaving Earth.
Jerry
