Mass can not slow time.
Started by brian334, June 25, 2009, 04:35:23 PM
Prophmaji
Time, mass, and gravitation are secondary effects.
The signature of the 'prime mover' (s)   is, or are,...Voltage and Current. Voltage meaning: polarized differentials in an oscillatory state, when it comes to describing matter.
Perfect current flow - identical across/through a given 'area', or group of oscillatory 2-d stress field interactives (multiple 2-d field interactives integrating - thus a final vector describing subatomics - thus describing 'matter') denotes loss if time and loss of differential as described in 'voltage'. Which leads to collapse of time and mass (local to the current flow). The 'mass' remains in our 'outer world' as the differential to the greater whole does still exist.
These are oscillatory resonant systems based on the given 2-d infinite stress fields at their integrative point thus creating the 3-d world through these 'outer' differentials.
Thus mass, time, and gravitation are external and not primary effects, and can be 'modified' or manipulated through the use of resonant and oscillatory manipulation of current and voltage.
To clarify: all --space, time, matter, energy, gravitation, and dimensional egress can be manipulated via controlled aspects of oscillation of current and voltage-in whatever form it may take.
Thus this entire forum can be seen to be doing exactly that in all aspects of all experimentation.
Do you see it now?
Essentially 'mass' cannot slow 'time', it may do so, but the effect is secondary to the heart of the issue. Manipulation of oscillatory resonant aspects of current and voltage  (the essence of the dimensional protrusion of matter into what forms this dimension) CAN do so. And DOES.
Thus the essence of everything on this forum that - works- . Every aspect that is speculative/speculated via observation of and through recorded history of instances, all of them - all point to this exact single point. UFOS, Dimensional egress stories, gravitational manipulation, transmutation, Bedini, Tesla, Gerlacht, Hildiger, (Gabriel) Kron, Pyramids, Newman, Meyer, etc...- all of it works through this single point. Every single anomalous point in science, all relativity and quantum considerations, the whole ball of wax, in all ways can be modified, maintained, created, destroyed, altered, etc..all through this point of resonant manipulation of current and voltage in some applied manner.
Do you see it now?
brian334
A perfectly good example of gibberish.
Einstein would be proud of you.
brian334
I think atheists like Einstein can’t deal with the notion that the universe is infinitely big and the universe has existed forever. So daum people like Einstein make-up stuff.
sm0ky2
Quote from: onthecuttingedge2005 on September 24, 2009, 03:24:52 PM
Hi Brian.
According to peer reviewed physics anything with mass can never achieve light speed, only massless objects can achieve light speed. even an electron can only achieve 99.999% light speed and that took the power of 300 Hoover dam hydroelectric plants to achieve it and that was for just 1 electron.
Jerry ;)
for something as large as an electron, this may hold true in most instances (not all), but even light itself (photons) have mass.
This has been undeniably proven, though most of science tends to deny it, even in the face of such evidence - such as momentum, impact force, ect of a controlled photon.  The mass of a photon is well known, and well rejected by scientific theory as a result of certain fundamental assumptions, with which a photons "mass" would interfere.
until such theorem are accurately corrected to account for these 'fudge factor' assumptions, science will continue having to deny that mass can achieve such speeds.
Ed Leedskalnin demonstrated decades ago, a method of sending electrons at FTL speeds (though that was not the conclusion he had reached at the time).
This was confirmed in the early 90's in an IBM laboratory, when they send electronic signals across a warehouse at FTL speeds. With outrageous claims of "teleportation", IBM was forced to abandon this project.
the mechanics behind this are quite simple, an objects velocity is determined by the resistive magnetic forces associated with propegating matter through space.
Light propegates its own magnetic field, through which it travels, and is not subject to the same resistive forces (except when passing through or very near the strong atomic field or a field of comparible strength).
i propose that the mass of a photon, is derrived from its Energy,
in the form of m= E/c^2 . - this can be conclusively verified by a measurement of the momentum of a photon of known energy.
which correlates to the calculation of P=E* frequency/c^2 . though Plancks relationship tells us that  P=E/c . :which only accounts for a portion of the photons energy, and to derrive the full energy requires the use of a fudge factor, commonly known as Plancks constant. remember that Planck's constant is
h = E /c * wavelength = ~ 6.6 x(10^-34) J*s
which is the energy required by the photon to propegate its magnetic field throughout one 'wave', divided by the time it takes to complete that wave(frequency)
and.. since wavelength * frequency = c
E=mc^2 holds true, even in the case of a photon.
Now:  how does this relate to slowing 'time'? the mass of a photon does not slow time.
Increasing the mass/energy of a photon will increase its frequency and decrease its corresponding wavelength. From our perspective, the photon's "time" will speed up.  From the photons perspective, our "time" will slow down.  but the ammount of "time" that passes during any sequence of events from the perspective of the observer remains constant as defined by said unit of measurement.
i.e.: 1 second, is one second from either frame of reference.
though looking from one into the other, things may appear to take a longer or shorter "time" to occur. This is only apparent, because of their relative speeds - "time" itself does not change.
That is one of Einsteins biggest assumptional flaws in his theory of relativity - that "time" can actually be altered by a relative state of motion.
mr_bojangles
anything can be overanalyzed to oblivion
i can make the argument that nothing exists at all
mass can achieve light speed if on the edge of a black hole
time is nothing more than a concept of another perception
its a sense, like tase and sight
sight is having the ability to recognize a specific type of matter due to a specific band of light that allows us to "see" we can barely actually see anything comparatively speaking, yet we still believe sight does exist
so the concept or sense of "time" is more so our ability to observe a small portion of "time" by comparing our bodies decay to that of everything we come into contact with
the center of a black hole time does stop
light can be converted into matter, its merely a form of energy
if a person was able to achieve light speed, their body would decay at an extremely lower rate than that of a person not traveling the speed of light "time traveling" forward
i believe what you are saying is time doesnt not actually exist, therefore something tangible cannot affect something that is a concept
our perception of time can be slowed by large amounts of mass as well as relative speed, were just incapable of generating enough energy to do so
i will agree that time is not real, but i disagree with mass not being able to manipulate our perception of time
"If at first you don't succeed, try, try again. Then quit. There's no point in being a damn fool about it."
-WC Fields
