0 Members and 233 Guests are viewing this topic.
xenomorphlabs
Quote from: baroutologos on March 25, 2010, 10:34:44 AM
Xeno, single wire electron oscillation can happen as long as there is a capacitance that generally the free wire possess. This coupled with the fact that typical antennas operate at Mhz range then a considerable current can oscillate back and forth.
In the Kapanadze device for reasons i fore-explained there is neither a high frequency to justify the large current neither huge one-wire terminal capacitance nor excessive voltages (tens of kilovolts range)
Actually you can calculate your own the amperage movement in a "single wire" by multiplying the Capacitance  * Frequecy * Voltage on free terminal. (generally single terminal capacitance is on the pf range).
Then you will come to my words ;)
Well something for sure pumps that amperage through that wire.
It is much more clear to me how that actually happens in Smith´s secondary
which is "somewhat" a closed circuit than in Kapanadze´s secondary which "seems" to be an open-circuit.
From the possible schematics for the replications it seems that the replicators have closed the secondary circuit (and have no ground).
I would focus on a closed circuit variant first, since this seems to work for those guys.
Hmm, i am just thinking since the single wire goes into the ground. What if you take the earth as a capacitance into the equation, since you can look at it as a large capacitor?
forest
Thinking about tabletop Smith device - look at oil capacitors bank. Don said that those parts are not custom made and they look like ordinary 3kV or 6kV ones joined in parallel to have bigger capacity.
He said this device will produce 16kW output and I believe it was estimated by measuring total energy in capacitors and the speed of recharging them from device.
Btw, why we cannot recharge capacitors from electostatic forces ? What is the problem here ?
Diodes are probably common one rectifier diodes from old Tv set.Estimating by size around 3kV/10A each.
forest
Here Smith is describing device which is very similar to Kapanadze. Look at the output transformer http://www.youtube.com/watch?v=pvBOVB9Au0s&feature=related
xenomorphlabs
Quote from: forest on March 25, 2010, 01:33:22 PM
I agree with the output transformer similarity. But that loop is still closed.
But who knows maybe there is a cable in Kapanadze´s outdoor experiment that closes the loop that one can´t see.
The only problem i have with that Smith device in that video is (and i mentioned that in the Don Smith thread already) that i really don´t understand how he expects to change a kHz frequency into 60 Hz by adding a resistor in parallel ACROSS the output transformer L1 coil.
When you look at the physics of driven circuits, you will find that the steady state of every driven circuit will be equal to the DRIVING frequency
no matter what the self resonance frequency of the driven circuit is.
Because the resistor-coil circuit will constantly see the changing voltage of the driven L2 coil of the left transformer at 30 kHz, how can it then resonate at 60 Hz?
The only time it could possibly do that would be when the spark gap fires but i don´t see how you could get a consistent 60 Hz waveform with the short spark gap time.
But to be fair, i am not an expert on oscillators and think it needs really to be tested to be absolutely sure if this works like he sais or not.
Maybe i am also totally wrong, but that´s what the literature sais.
baroutologos
Xeno and all,
dont rely too much on Don Smith's saying since is proven much of it (if not all) to be bull..
I explain. He repeatedly said that modern NSTs write on label 10Kv at 30mA whereas the consume some 80-100 watt.
Don Smith repeatedly said that this NST already is OU!!! and challenged anyone to disprove his words! Ha!
This is plain bull! My automotive NST writes on label 9500 Volt at 30mA yets it consumes some 3-4amps of 12 volts  35-50 watts.
I have tested again and again and calculated capacitative discharges. Hell no, it does not produce OU in any case. Its just a measure of brightness or the amperage the NST produces under dead short (or ionized gas) not at 9,5 Kv.
This is one thing. He has said too much! I do not even bother at repeating them. On this i will agree on Omni. See what works and try to replicate based on your understanding rather the bull we are fed all time.
