0 Members and 132 Guests are viewing this topic.
Ghazanfar_Ali
@ Verpies (STAAAR Device)
Dear Friend, I thoroughly went through their videos and photographs which they have uploaded in their Lithuanian website. I am uploading one of their pictures duly labeled by me. I think 1 T coil is visible for 15 T winding. However for 50 T Primary it is not visible and still is a big question. May be there is only 1 such coil perpendicular to 15 T and 50 T is left without it and this 1 T with 15 T is serving the whole purpose. But again I highlight that they wrote, "Each generator has feedback with 1 Turn on coil." As far as I understood, there is only one 1 T coil perpendicular to both 15 T and 50 T primary windings. However it is in series with 15 T winding only. And it is providing feedback to both generators due to mutual induction. What do u say?
Waiting for your idea.
Thanks
Ghazanfar Ali
Ghazanfar_Ali
@ Verpies
Another query is, do both the gens have a common ground. If it is like that then this coil will be in series with 15 T and should be located between 15 T and outer connector (shield) of BNC of gen connected with 15 T winding. And thus provides changes in the phases. Questions and Questions. I think STAAAR team really worked hard to upload only two of their videos in English. I am still waiting for their Instruction Manual in PDF abt which Arunas mentioned in his video that he is working on it. :)
wattsup
@All
Man oh man, I tried to make a youtube video that I uploading but the noise from the spark gap is so loud you can hardy hear me talk. Hmmm maybe that's a good thing. lol
http://www.youtube.com/watch?v=_FAtfk2CY6g&feature=youtu.be
Should be ready in about 15 minutes.
Anyways, I am showing in this video What @ronotte showed. The setup is like the diagram on the front end. Flyback, D1, C2, Spark Gap, but I am not using a variable cap because I don,t really need it since i can vary the Caduceus Coils position that is inside the output coil as well as my core position. Also, I can vary frequency, width, amplitude and voltage to the flyback. Some places the best response was with 24% duty.
The output was direct from the two coil ends together and from the center tap, since is did notice more output this way. But now I will get the last part of the output set-up with another spark gap, diode and cap. I just wanted to take this step by step. Lot's of fun but the spark noise is just murder so I can't run it loo late at night. lol
More soon.
wattsup
PS: I put an image below but if you need a higher resolution image go here...
http://purco.qc.ca/ftp/Tariel-Kapanadze/Wessley-WNY-Group/build6/
ronotte
@wattsup
Congrats: you did it ;) Only some considerations:
1- You are seeing that in order to have a minimum real output you need a very strong HV/freq source (as I did in the beginning using the 9KV Ventex neon sign indicator's Power supply). The noise coming from the SG is an indication. In that condition, as you have experimented, all electronic devices in the nearing go berserk ??? indicating HF pollution being enormous: I warn you to stay at least a couple of meters far from the coils or you are going to suffer many headaches or other worst things. The reason I reverted using a much lower input voltage/power (max 1.5KV hence a silent 1KV arrestor as SG...no noise at all) has been just that. The scope being to set it up in a safe way allowing to stay safely and for hours near the coils...and only then rise the input power to see the real possibilities.
2 - Yes, your lamp a little lighted...but is it so important...and useful? probably on lamp only a fractional watt...certainly far from any OU. I tell you that I've not been able to reach more output regardless of any possible tuning. I thing that the STAAAR team changed direction toward capacitive coils just for that reason. My personal opinion is that this is not the best solution but just an effort (very clever) to try an idea.
3 - Please pay attention to waveform you see with probe near the Caduceus input wire (after SG1) or on output pickup coil (before SG2): I have seen briefly on your scope a well known wave's image and I tell you that it is wrong as it shows max just after the SG's firing: in other word you are seeing an inverted triangle. Look at my last pic: the trumpet shape starts with low amplitude and rise exponentially up to a max when the SG fires. I took lot of time to arrange tuning in order to get such an output to be considered fundamental to have an OU chance. Once you see that then you have to maximize the exponential amplitude: for the moment I've been unable to obtain more than showed (about 400Vpp) but it is also true that I am using only 1.3-1.5KV input.
My fear is that next step could be completely different to allow the jump up to next level...remember the Tesla many pats about the bifilar amplifying coil...and the V. Utkin paper that I urge you to read many times and try to understand the much not said but implied...then apply that new knowledge to our practical implementation.
Roberto
ronotte
@freeenergyinput,
very interesting: would you please (if possible) annotate that image ee.jpg in English?
Thank you very much
Roberto
