0 Members and 18 Guests are viewing this topic.
AbbaRue
Quote from: Hope on January 12, 2012, 02:10:21 AM
I made a discovery today as well concerning a simple dual magnetic diode consisting of 9 disk magnets the center magnet being connected to a coupling capacitor passing the AC source. The output ends of the magnet (outter two ends of stack) will have original AC + the added plasma streamer attracted from the change of the AC pulses from the surrounding enviroment.  (A word to the wise)
@Hope Can you give us a dia. of this setup?  Sounds interesting!
ronotte
Caduceus & pickup coil device UPDATE
Hi all interested. Today I did some very interesting tests in order to document what happens when you move the ferrite rod inside the Caduceus. The reference schematic is always the same (as you can see in my previous collage pic) and all the waveforms are collected at the pickup coil (before the diode).
Just for reference I firstly obtained again the famous "Reference trumpet" like wave by carefully positioning of Ferrite rod. This wave has a repetition rate of about 2.8msec and is peak to peak amplitude is about 600V. center screen is the 0V reference line and the 2V scale (lower left) must be multiplied x100 as I used an HV probe.
Inserting the Ferrite rod there is a point where it is possible to see a very exciting situation: just after the SG firing the trumpet leg shortens to about 0.9msec and at the end it jumps to a max level where it does stay till the next firing (you can see also the SG's created peak with duration less than 0.3usec) that happens after 7msec. The amplitude is also big as it swing from -950V to   950V. Please note also the almost 'vertical' transition from the trumpet's end (level about 160V) to the flat top at  950V (Pic= Almost continuous output).
Do you want to see what inside the big wave's envelop? here is it (Big wave detail). Please note the top/botton wave's truncation due to SG presence and of course how the trumpet transforms into the continuous wave :)
I think that there is still so much to dig.
Roberto
steeltpu
translation into English of Kapanadze doc that FreeEnergyInfo posted.  This was a 20 Megabyte document with pictures.  This translation attached is only text.
Hope
Quote from: AbbaRue on January 13, 2012, 07:38:24 AM
LOL    I have to laugh about an half hour wasted trying to learn a simple cad program (double cad xt).  I better just draw it and scan it.   I have been out of the loop years and though I knew Velleum well enough, I am not able to make a line not jump into the center of the circle on this cad program.
Yes I will make you all a schematic.   The printer I use is wireless and the friends are sleeping just now (12:15AM PST) so I will draw it out tomorrow and post it.    I thought my words were clear, if you want to use just a 12vdc battery and connect it to 5 magnets and measure the flow then reverse the leads you will see the arc (plasma) jump across, then a no flow condition will be measured.   This is interesting effect and can be worked in to what I described tomorrow.
Use 9 magnets and the flow will be lessened but the spark on no flow will be like a small lighting bolt but bright blue.
PS  After studying the research original documents Andre got his E= Cat CF ideas from.   An educated guess about the secret catalyst is in order.   If Andre used fine iron particals magnetized (like copier toner) within the chamber the magnetic field would be unable to be held within the iron when heated enough and that field would have to go somewhere...   Then the first company he partnered with ,said "they found another way to produce catalyzed effect" so their effect is to use electro magnets pulsed perhaps.
Edited     please use neo magnets if you have them,  I don't know if regular types will work this way.
E-Cat   may be a cleaver elude to electronic catalyzer and the only electronics in his first device was the heating coil (or could be the action of the magnetics being transfered while heated)
FreeEnergyInfo
Quote from: steeltpu on January 14, 2012, 01:09:11 AM
THANKS ...THANKS ...THANKS ....
NAZAR ...
VIDEO
www.freeenergylt.narod2.ru/nazar/
www.youtube.com/watch?v=4xjFwfuXp3Y
www.youtube.com/watch?v=b77bZFBZvko
www.youtube.com/watch?v=sPgKKHMc81A
FREE ENERGY  ==  FREE INFO !!!!!!!!
