0 Members and 323 Guests are viewing this topic.
forest
Definately the silent spark in Tariel device is part of secret. The same silent spark is visible in aquarius device inside near the vertical standing coil/capacitor thing.
Ghazanfar_Ali
@Verpies
Yes u r right. I have checked from their discussion forum and user manual. It calculates both for DC as well as AC. The Wattmeter does not calculate power factor for non sinusoidal waveforms hence keep it = 1 for arbitrary waveforms and calculate product of average instantaneous Vs and Is. The circuit is quite simple and its hardware can be replicated easily.
Ghazanfar_Ali
@Verpies
Correction..... Average of all products of Inst Vs and Is. :)
dllabarre
Quote from: wattsup on January 19, 2012, 08:26:47 PM
OMG again. Just by going through this exercise, I realized something. SPARK GAP (SG) NOISE. The second SG made very little noise, almost silent. Is it possible that the TK Green Box (GB) visible open air spark gap is the second of two, of which the first is in the GB not only because of the higher voltage needing to be protected from any inadvertent shock but also to mute out the spark sound because his second spark (the visible one) did not make any special sound that we hear in the video. I wonder if anyone can do a spectrum analysis of the GB video when the camera is right beside the GB while it is sparking away.
wattsup
I've posted here a few times and on other forums a picture that is supposed to be the inside of the Green Box.
No one has confirmed or denied it.
The shape of the box in the picture is the same "odd" shape as the Green Box.
The HV wires exiting the picture lines up with the HV wires going to the outside spark gap.
The wires entering the picture line up with the wires entering the Green Box from the power inverter in the videos.
And true to Tariel's secrecy there is a section in the picture that is covered up so we can't see what's in it.
What we do see in the picture is a Fly Back, spark gap, capacitor.
I don't have it on this computer but will find and re-post it when I get home.
DonL
wattsup
Quote from: dllabarre on January 20, 2012, 10:34:26 AM
DonL
@dllabarre
Please do not forget.
@all
Regarding the sound waveforms posted by @duff, with thanks,, I am not apt enough to interpret them. Maybe if @EMDevices was around he could help us out since he has done some great sound analysis in the past.
First, SG in these cases means Spark Gap, not signal generator.
Well, I just managed to get the thing going again and the output bulb just started to light up very dimly and bang, it all stopped again. I am sure it is another diode that blew. So it is very categorical that anyone trying this will requires the right robust components that I will order today. Real HV diodes, caps and a variable capacitor (which I never had).
TK's GB rinky dink visible SG was enough to light up those 5 bulbs. That in itself is a major feat. The Caduceus Coil in the WNYg devices may be to limiting in terms of its ability to impart to the outer pickup coil. Plus, I do not want to go back to the yoke because the cores are getting  hit to hard. So what I am thinking is since the first stage SG1 section is more them complete (except for more heavy duty HV diodes that I need), I think the main variable now is to work on variations of the Caduceus Coil. The 5 wire parallel wind could be modified to all series to resemble more of a Rodin Coil set-up so that the SG1 spark energy can recirculated more times inside the output coil. Also, another Caduceus Coil wound with tighter turns (as we have seen others try with the TK coils) would concentrate this energy more then it is doing now. There are many ways to play around with the CC winds to find the most effective method and hopefully be so much more efficient so that the SG1 stage could be driven with much lower energy.
@ronotte
Yes, I just blew another diode when I increased the SG1 spark distance, the snapping of the spark was so intense and all of a sudden it all stopped. I do not mind because it is all part of the learning process. Once we know what to do and what not to do, this will eventually streamline the process for others. I noticed in @stiveps' last video that he was using some things that I have never seen before. I grabbed an image form his video. What is the component at bottom right and also, notice how fat his spark is?
I will be out this afternoon and all weekend at a Jam weekend with about 45 other people mostly musicians. This has been in the works for months now so I will be back on Sunday night. One of the songs will be Imagine by John Lennon. Yep, just imagine.
wattsup
