0 Members and 482 Guests are viewing this topic.
FreeEnergyInfo
aidas new experiment ....
The original scheme that you see may be an error from fatigue. redrawing, and so on
  principles visible ....
The obstacle to working with this facility available to protect the equipment we have tried so not filming, will soon be full of information ....
Tesla coils have a free time elktronu on themselves, as in the video .....
  very very very important thing capacitor connections ....
  This version of the scheme under test ....
INFO...
www.freeenergylt.narod2.ru/aidas2/
abc
What happened to the "working OU" device? :D
Not working anymore? What a shame:'(.
a.king21
Quote from: abc on January 29, 2012, 12:20:12 AM
It has been replicated in New York. Ha Ha ;D
ronotte
@kator01,
- Cu slotted tube: tube's lenght= 10cm, diam=10mm, wall thickness=0.6mm, slot width 1mm, slot lenght 10cm
- Ferrite rod diam= 9mm, lenght=10cm
- Cap on AV plug may be any value between 1n and 10n: it set the spark repetition time, the lower value the faster timing
- Cap on output diode. I used 1n in order to see well the staircase waveform.
have fun
@itsu,
it seems to me that you are using an enormous kacher (450t on sec) It may be good as it could deliver probably 3-5KV @ a lower frequency but then the 1n4007 rated only lKV are dangerous ???  I warmly suggest you to use standard HV diode rated at least 15-30KV @100-200mA. I've seen also that you used the standard bridged output to rectify/drive the load: that's not what intended by the STAAAR team as it does not provide for blinding the lamp load presence.
Roberto
