0 Members and 160 Guests are viewing this topic.
grizli
Quote from: madsatbg on March 26, 2010, 09:24:45 AM
hello,
this experience I did it
scheme applies
I placed inside an aluminum, not copper
best wishes
madsatbg
You are AUTHOR if the circuit ? how you came to this solution, what it does? whats principle of operation
IS IT OU or not ?
Inside is a aluminum LOOP(tube that is not closed together) , is it connected to anything electrically ?
p.s THANK you for coming here ans SHARING with us !!!!
madsatbg
Quote from: grizli on March 26, 2010, 09:49:14 AM
IS IT OU or not ?
Inside is a A LOOP(tube that is not closed together) , is it connected to anything electrically ?
This idea is from admin http://next-energy.ru/,
I'm modify it
Tube not closed together.
Is not connected in this wideo.
madsatbg
grizli
Quote from: madsatbg on March 26, 2010, 09:30:39 AM
I want to share my vision of the scheme in connection with the following
video
http://www.youtube.com/watch?v=74g7GrZdMeA
suggest the scheme
A
madsatbg
is it HF SMPS invertor or its classic invertor that has DC and after DC has output mosfet switches that makes 50hz !!!
Or does this invertor give 50hz 220V or some HIGHER frequency???
Can instead invertor classic 1:1 50hz transformer be used ?
what is number of turns relation in that coil
Thank you !
Omnibus
@madsatbg,
I'm curious too, have you done any measurements yet of the input and the output energy or you're just demoing the effect of various cores by observing the intensity of lamp light?
starcruiser
Quote from: madsatbg on March 26, 2010, 09:42:15 AM
yes, you right.
wire is 4mm2; 2 x 24 turns and 1 x 28 turns
with gratitude to the admin of http://next-energy.ru/
Thankyou for the answers to my questions I appreciate your responses.
as mentioned by the OP, can you tell us what is your input versus output, do you see any gains?
Do you use a core as mentioned?
Regards,
Carl
