0 Members and 37 Guests are viewing this topic.
27Bubba
"3) Make Tesla coil(TC) what runs on AV plug to primary from one wire of flyback transformer while other flyback from flyback LC circuit end goes into secondary and then put it into resonant oscillations, then harvest ionized air from hot end(ionizer)  of TC to capacitor what got spark gap to the load which got grounded another end."
Those abbreviations killing me!
What AV and LC stand for? :D :D ;)
hartiberlin
AV= Avramenko plug= 2 diodes and 1 capacitor put on 1 Wire high frequency AC carrying wire,
results in DC voltage output on the capacitor.
LC = Coil and capacitor put in parallel= LC tank circuit.
P.S:
1. Wesley or anybody who visited Kapanadze , did you ever see
Kapanadze use a scope and did you see any scopeshot of the output
waveform that powers the lightbulbs ?
2. What is said about the core of the coil in the April 2004 video ?
Is this just plstic or are there ferrite rings in there or a aluminium or copper tube
in there or ferrite loudspeaker like magnets ?
Did TK ever say or hinted or showed to anybody what his core consists of what material ?
3. Are you sure he used copper wire for all his coils or could he have used also green plastic isolated
garden iron wire ?
This last question is very important, so read my next posting please !
Regards, Stefan.
P.S: Wesley, I think you are do much too complicated theories over here. I think the
secret is much simpler...
hartiberlin
User Microcontroller shed a very important light onto the main function
principle of the whole energy amplification process with this posting:
Iron-56 (56Fe) is the most common isotope of iron.
About 91.754% of all iron is iron-56.
Iron (Fe) consists of four isotopes:54Fe,56Fe,57Fe and 58Fe.
This point is also where the whole dream alters since Steven Mark (and we) were always assuming the thing would run forever, but if iron56 is it's fuel it will run out, eventually.
Luckily we got 91.754% of all iron to go.
What's important to note here is that alternating magnetic fields running at certain specific frequencies can alter nuclear conversion between the elements thereby releasing energy.
Steven Mark was dead on with his words about the atomic energy commission and the connection with his device.
I won't go into any detail about how this mechanism works but i can tell you that when this 'nuclear event' happens small bursts of high energy (y-rays) are the result.
This is what Steven Mark observed in his very first experiments and he rightfully called them kicks.
Notice this has got nothing to do with the earths magnetic field, but he had no idea about what was going on.
Okay, now we know, that IF WE USE IRON WIRE we could get this radioactive decay when excited by magnetic or electromagnetic pulses
or sparkgap pulses !
So I guess when Tariel found this huge COP = 86  effect, he fiddled around with Tesla coils and had no copper wire and just had some iron wire laying around
and used this for this Tesla coil and suddenly saw bursts of pulses on his iron wires...
I think he then put his isolated iron wire into this 5 turn holow copper coil and pulsed the iron wire  with High voltage pulses from his sparkgap.
This releases many gamma ray bursts from the iron wire and excites the radioactive decay and also releases beta decay, which are perpendicular
(90 degrees to the wire) flying out free electrons. ( charged negatively).
These electrons are then captured on the big 5 turn holow copper tube coil and thus this coil charges up very fast very highly negatively.
Thus drawing this potential from this coil versus the other coil components we can draw then a pretty high power level and also these gamma ray bursts will
induce magnetic ossillations inside the other coils wound around there.
So I guess the real power source and the huge COP= 86 is due to the radioactive decay excited by the sparkgap firing the high voltage
pulses onto the iron wire.
I can think of no real other explanation than this at this huge COP overunity factor.
All the other videos I have seen on youtube, where people tried to rebuild the Kapanadze devices
with just copper coils and no iron wire in it, deliver never these huge COP factors, maybe only 1.5
at maximum or maybe 2 at maximum, but never COP= 86 !
That is, because they did not use Iron wire and so did not use this radioactive decay of the iron
isotops ?
Can somebody, who has a working Tesla coil can modify his coil to use iron wire in it and
wrap a bit alufoil around it and see, if this alufoil will charge up very fast and deliver real power
versus the ground pole ?
Many thanks.
Regards, Stefan
aether22
Roberto, it is very fortunate to have someone to ham it up with.
Your knowledge of transmission and reception should help if you don't let it hinder.
Let's look at the EH antenna [size=78%]http://www.eh-antenna.com/EH_HZ.pdf[/size]
We can see that this phases capacitive HV with magnetic fields in the right phase to mix EM waves.
One of the concepts with this appears to be (though I'm not totally clear) is that in normal antennas it is a difference in the rate of transmission between magnetic and electric fields that cause the fields to reach the correct phase some distance away.
This includes the someone unusual claim that magnetic fields propagate instantaneously.
That has to be taken with a grain of salt, anyway it seems that correct phasing of these electric and magnetic fields can create dramatically increased radiation resistance.
Also interesting is that in this antenna is a different topology of apparent radiation that is separate from the usual spectrum and can pass through an aluminium shield.
Anyway the gist of this is that by correctly phasing and crossing electric and magnetic fields it might be possible to have little near-field and plenty of emitted radiation.
To test this it is ideal to create a highly directional highly efficient transmitter and then capture the wave in a well selected high Q resonant antenna.
This should readily lead to over-unity.
Maybe we could design something, sure wish I had a signal generator right now.
So how do we capture as close to 100% as possible?
Thoughts of satellite dishes and wave-guides are running through my head.
Frequency?  if directional radiation or waveguides are used then I'd guess frequencies of 75mhz minimum, otherwise 50khz to 10mhz sounds fine, but only if you can limit the size of the nearfield, we want to avoid transformer action.
Trying to gain overunity from only a portion of the emitted wave is going to be hard, so either it must be encircled by antennas or a way to focus the radiation.
Need an antenna expert.
27Bubba
Stefan, thank you for explaining the abbreviations.  Also, I think you in to something about using the metal core in the TK coil. Trough my experiences dealing with industrial electromagnets  the core always was soft annealed metal. As per your suggestion to stuff the insulated black iron wire into the copper tube is definitely worth trying, except who sells a small quantity of 2mm dia wire of this kind?
Cheers.. ;)
