0 Members and 145 Guests are viewing this topic.
nightwind
Kapanandze Video: http://www.youtube.com/user/FreeEnergyLT#p/u/14/lFiaBKW50yA
At 5:54 , TK places a voltage sensing light probe (looks like a screwdriver) on the line & load side of the breaker that is turned off.  The light probe does not light up (no static voltage sensed?) on line or load side.  He switches the breaker on and the lights turn on........that is amazing.  Electricians use these to sense "hot" circuits.  I wished he had done it while the lights were burning.
d3x0r
Just musings....
Quote from: aether22 on February 08, 2012, 08:37:58 PM
This includes the someone unusual claim that magnetic fields propagate instantaneously.
That has to be taken with a grain of salt, anyway it seems that correct phasing of these electric and magnetic fields can create dramatically increased radiation resistance.
That's an itnersting tought, but you don't have magnetism without E?  it's always some sort of EM?  is there a lag in the motion of the magnetic field compared to the object moving? other than flux likes to remain attached, and I don't know how you could see the magnetic field without affecting it (something like applied in a plasma field?)   ... but instantaneous... that's more like voltage is faster than the current... I also read something that led me to beleive that the E part and the M part of an electron moving are not cause and effect, and exist simultanously I don't know what the M field would look like when the E isn't moving (other than we're moving in a galaxy at some rate so everything's moving, and should have some sort of general field)
Frequency?  if directional radiation or waveguides are used then I'd guess frequencies of 75mhz minimum, otherwise 50khz to 10mhz sounds fine, but only if you can limit the size of the nearfield, we want to avoid transformer action.
(for ways to effect power transfer) capacitive, inducted and near field, is there a far field?  quanum entanglement?  isn't magnetic flux entangling, that once it's participating with another object, that flux wants to remain interacting (someone posted a kacer video with a computer case as a capacitive load, and made the sparks dance all over)....
Need an antenna expert.
I might include looking at caducues, and bashar, antanna too (cone, pancake, hemispherical, caduceus,... square sides? pyramid)  a conical helix is a broadband antenna - good for picking up frequencies from all over the range - each loop is an L... or 90 degree so L+something(L) ?  but then it wouldn't have received the first L?  I was looking up to see what a caduceus is... one take is 90 degress winding (rodin-esque, but on a cylinder instead of a torus, and the bashar is a intersecting conical caduceus, but at a slight angle, so it's a bi-filar oppsing windings( which makes it actually all in the same direction when you connect the ends?)
hartiberlin
Quote from: 27Bubba on February 08, 2012, 09:04:08 PM
Stefan, thank you for explaining the abbreviations.  Also, I think you in to something about using the metal core in the TK coil. Trough my experiences dealing with industrial electromagnets  the core always was soft annealed metal. As per your suggestion to stuff the insulated black iron wire into the copper tube is definitely worth trying, except who sells a small quantity of 2mm dia wire of this kind?
Cheers.. ;)
You get this green plastic hull isolated iron wire in each garden store.
It is used for plants and fences...
It is also pretty cheap.
Hope this helps.
Regards, Stefan.
hartiberlin
See this:
Isotopes of iron From Wikipedia, the free encyclopedia Naturally occurring iron (Fe) consists of four isotopes: 5.845% of 54Fe (possibly radioactive with a half-life over 3.1×1022 years), 91.754% of 56Fe, 2.119% of 57Fe and 0.282% of 58Fe. There are 24 known radioactive isotopes and their half-lives are shown below. See Brookhaven National Laboratory Interactive Table of Nuclides for a more accurate reading.
Read more here:
http://en.wikipedia.org/wiki/Isotopes_of_iron
Wow, 24 known radioactive isotopes !
I did not know this...so probably all iron metals could be excited to radiate more
via High Voltage or strong magnetic pulses...
and release this way much more energy.
Just put some other metal foil or copper tube around the iron and
catch the flying off beta decay electrons and this way charge up your circuits and capacitors or excite LC tanks.
Regards, Stefan.
aether22
I received a message from someone, the info seem interesting so here it is.
You got that right and Hartman is leading the way by censoring posters that describe the process and burying information that does make it online. Watch for the rapid series of long posts right after a good post.
A Caduceus coil is a standing wave longitudinal wave generator. (Similar to a superluminal photon lasor) That is not what we are interested in here. What you want is a displacement current standing wave generator. That is what the copper tube is and here is how it it is built:Run some HV spark plug wire all the way through a copper tube with a foot of extra wire protruding from the ends..
Next, attach one end to the Earth ground and the other to a spark gap. When the HV wire shorts to ground, the cavitation of the spark gap produces a displacement current standing wave in in the copper tube which is transferred to the coil sets located inside that field.When this standing wave bounces the electron off the coils inside that field, they are no longer being dragged down the surface of the wire in a spiral and they do not produce the friction losses and heat that is normally produced in a transverse wave coil.The coils below are two smith coils end to end with a gap wired against each other. Hubbard wound them around in an endless  circle - same basic thing. One charging the next stepping up. At 85KV an unbound  virtual particle called neutronium is created. Falls below hydrogen on the periodic table.Voltage is photon force carrier acceleration, current is mass. The more voltage, the more acceleration.
Quarktoo was right when he stated:
1. All free energy devices convert mass into the atomic energy contained within the mass.
2. All free energy devices use acceleration to accomplish that.Einstein was right when he stated "Not all things that count are countable" Einstein was wrong with his E=MC2. It is actually E5=MC2Einsteins version only takes mass to matter.
That was to support the false notion that mass cannot be created or destroyed. Einstein was a hack working for Rockafeller's oil industry and destroyed the work of many good scientist. Paul Dirac and Miller were just a few.The bottle neck hanging off some of Kapandzi and SR's coils is backing iron or magnets to give that displacement current longitudinal force. Otherwise, the electron just bounces up and down off the wire.
Think of it this way - What you want is a bounce pass of a basketball.Broken symmetry is the next part and that is why there are two coil groups and how the dipole is not destroyed....and finally, the ground wire running through the center is a 1/4 wave converter to give the other half of the circuit the proper phase angle.And there you have it, Kapanadzi in a nutshell. Hartman, Pirate and others have suppressed ALL of this information is the past posted by Q2. This place is a big scam, intel gathering operation filled with spooks. For all I know, you are one of them too. But I care, I just like getting my game on.
Enjoy
Note, I mean no offense to Stefan, just reposting in it's entirety.
