0 Members and 37 Guests are viewing this topic.
andrea76
hi all about the small nuclear reaction in the certain type of iron see the frame at min. 29:31 of this http://video.google.com/videoplay?docid=-1944827568401901581
Acca
 I am quoting  “aether22      “I think I get why there is chit-chat...”
”No one has yet managed to independently replicate power out of the caduceus (and claims about the new ion thingy have not been made yet) but several skilled people have tried. Failed replications are like a poison in this field, it only takes a few and parts stop being ordered and people hop back up on the fence.
'They' likely know this and use it from time to time to reduce our inclination to build.” You are absolutely RIGHT !! Way too much “non-sense” I have been on this forum now for more than ??? well.. since the last failure of the “Kapanadze generator” that I have built in June of 2010 and posted it right here.. I did NOT like the microwave oven transformer and the 5000 volts driven in to the ground !!  The design based on J.L.Naudin schematic.. I did like his great video clips and his photos. My photos are still on his web sight under the kapagen replications as well as others, I did not consider that a failure just a learning lesson, I did spend about $500 US dollars, however that is nothing considering that this device will basically free mankind from spending a disproportionate  amount of their income on energy.. And that is why I am here, failure is not an option for me.  “IT’S A QUEST” of a life time !! It’s the “Holy Grail” of energy, and nothing else matters as much as this in the improvement of the human condition on Earth….
Here are my latest clips,  as I have just started to assemble Kapagen #2, based of what I got from all “you” participants on this forum.. I really “THANK EVERY ONE OF YOU” .
As to my cost in building this device, well it’s priceless.. .
Ferrite Core Metaglas for the Kapagen power generator Video No.1
http://www.youtube.com/watch?v=ShnMvdZ-TEw
Ferrite Core Metaglas for the Kapagen power generator Video No.2
http://www.youtube.com/watch?v=S5er0yBQcxk
MSD for Kapanadze generator, for spark generation video No.1
http://www.youtube.com/watch?v=LTszHR_Jigc
MSD for Kapanadze generator, for spark generation video No.2
http://www.youtube.com/watch?v=0LQ9BbmtovQ
[/font]
ronotte
Hi Harti,
your hypothesis is intriguing: Fe decay with strong beta emission could (?) explain the COP=86. Yes, we are not speaking about COP=1.xx hence the difference is mainly not due to standard well known electrical laws. So the 'garden' isolated iron wire usage does remember me the work done by otto, giantkiller and others (not myself, I always used copper wires)...anyway they all did not reached any OU (in my knowledge) not speaking of giant COP figure you mentioned.
All the other hypothesis about standing wave manipulation in wires or Copper pipes even if sounding I see it difficult to explain the COP showed by K and far from the K man knowledge: too complex. V Utkin is perhaps the more close to K device...but I think only partially. For example I proved the 'blinding' effect on the wesley's pickup coil, the trumpet wave on output...but until now 'checked' overall effects are light years behind what showed by K. I succeeded in adapting HV source impedance with Caduceus input (great!!...)...but until now I've had no results in matching the pickup coil output to load: a very difficult task.
So your Fe decay beta emission could be a way...BUT REMEMBER THAT IN ORDER TO STIMULATE A HUGE BETA DECAY IS IS NECESSARY TO DELIVER IT (the Fe electrons) > 8Mev (Mega ElettronVolt) energy as stated in my previous post, using our poor-man capabilities we actually are able to impart only Kev range of energies (max of 20KV ... normal TBC usable output is far less and also my kacher output max 2KV under load condition). 8Mev are typical of linear or torus Accelerators machines I used to work with in my far past. The eventual small effect possible  at 2-6Kev should be considered marginal, certainly not accountable for COP=86. But...what if K found a way to enhance the effect while in a positive loop? May be that peak energy suddenly rockets to Mev range for combined effects due to 1/4 wave resonation, standing wave build up, mechanical ferrite rod resonation, earth current, etc...so establishing a sort of avalanche effects. Well, only my own rumblings.
At the end it seems impossible (?) to me that we eventually could be able to obtain such effect just sliding  Fe wire into copper pipe coil (K always uses a big copper pipe but I do not remember to have seen any wire protruding...).
Anyway in the course of my FE experience I tried several time to check TPU for alfa, beta or gamma emission using professional nuclear detectors: never found any even small evidence (it must be said that I checked My TPUs so no iron wires...).
Roberto
Khwartz
Quote from: John M on February 08, 2012, 01:52:29 PM
"Could we say that by the means of manipulating ZERO POINT OF VOLTAGE
TK was able to achieve maximum current and no voltage?"
This condition occurs at resonance, when you can have maximum voltage and no current or have maximum current and no voltage.
I did an experiment where I had two identical coils The primary was connected to a signal generator through a 3 volt bulb in series. The secondary was connected to a 3 volt bulb in series. Both coils were coupled together through a ferrite rod.
When I tuned the signal generator the bulb on the primary remained lit until I hit the resonant frequency and then went out. The bulb on the secondary remained out until the resonant frequency was hit and lit to almost the same brightness as the bulb on the primary had been. When the primary was in resonance there was very little current flowing from the signal generator because of the primaries high impedance state. Likewise the secondary was also in a high impedance state but had maximum current flowing through the bulb in a resonant condition and the bulb lit.
For those who are skeptical, just try it. You also can't say it was an impedance transformation to match the signal generator to the load since the generator had a 50 ohm output and the coils impedance at the resonant frequency was something like 500 ohms.
I still think the way to overunity is through high voltage and resonant conditions. I just think we have to know what conditions to create and build to create it.
John
Hi John!
That is a very pertinent experimentation you made! Very thanks for having shared it  8)
I would say that resonance state is a kind of super-conducting state, an near equivalent of very cold state of super-conductance but at normal temperature, obtained, not by reducing the Brownian movement of the atoms, but by setting an orderly way to the atoms and/or molecules, like in a corridor when while everybody were going in any direction, then we set them to move with exactly the same way, and a way in agreement with the way the person who want to go through moves: easier to go trough in an orderly and "agreed" state than a random one, that my theory. What do you think?
Cheer.
xenomorphlabs
Where can one get the highest quality original upload of the 2004 workbench video. Where did it originate?
Best details can only be grasped from the highest quality version as the original recording is already quite lo q.
