0 Members and 39 Guests are viewing this topic.
core
Quote from: cosmoLV on February 09, 2012, 01:50:24 PM
This is an old soviet inverter.
The characteristic of device is that you need a inversion â€" the main reason is to isolate from AC "industrial Ground" /Device has own earth ground/ from ground electricity are not pumped out!
Anyway it needs a AC â€" this is important.
Tesla worked with AC currents â€" don`t foregt this!
ok, thanks. So the output of the old inverter has a true (+)220 volts and a true (-)220 volts (A-C) Kinda like using a 1:1 transformer with the secondary not grounded if I understand correctly.
But what is the purpose of 'plugging' the cord into the bench outlet then removing it?
Also, this 2004 device is 5kw, the green box device is 3Kw. The coil used looks identical, where did the additional 2Kw go? Is the output unlimited depending only on components used? In other words could he have connected an additional 1Kw load to the green box device? How is he calculating output?
-Core
Cap-Z-ro
RE: The iron versus copper debate...Nathan Stubblefield used a combination of iron and copper in his energy creations.
...and also, Ed Leedskalnin used steel, not iron in his energy system.
Regards...
Frederic2k1
Quote from: core on February 09, 2012, 01:45:13 PM
Kinda off topic but relevant to Free Energy.  This quote from Neil Keenan. This man filed a law suit in New York against some BIG players.
Looks like Mr Keenan is into the FE thing......thats good to hear.
-Core
What is the source for this quote by Neil Keenan ?
wings
Quote from: ronotte on February 09, 2012, 05:26:51 AM
Hi Harti,
your hypothesis is intriguing: Fe decay with strong beta emission could (?) explain the COP=86. Yes, we are not speaking about COP=1.xx hence the difference is mainly not due to standard well known electrical laws. So the 'garden' isolated iron wire usage does remember me the work done by otto, giantkiller and others (not myself, I always used copper wires)...anyway they all did not reached any OU (in my knowledge) not speaking of giant COP figure you mentioned.
Roberto
a process like this ....
So, according to the Prof R.L. Vallée theory, the required condition to get the Synergetic effect is :
a) To align the fields of the electrons and the nucleus of the carbon... (Fe) atoms by the use of a colinear E-Field and B-Field,
b) the energy of external photons (g) is used to absorb the kinetic energy of the electrons,
c) so, the stopped electrons can be attracted by the carbon... (Fe) nucleus,
d) a nuclear reaction begins: the Carbon ...(Fe) is transmutted into radioactive ....... (which has a radioactive decay of ..... ms)
e) then, the vacuum energy is tapped by the nucleus and the ...... is transmutted back to ...... while a strong pulse of .... Mev is sent (see the reaction below) .
http://pesn.com/2005/04/07/6900079_PROTELF_Proton-Electron_Fusion/
http://jlnlabs.online.fr/vsg/protelf.htm
core
Quote from: Frederic2k1 on February 09, 2012, 02:39:59 PM
I hope you have a lot of time on your hands. Go here http://www.divinecosmos.com You can read all about Financial Tyranny. This is the hard thing to digest. The big question we all have to answer is "What if everything we thought was right was actually wrong?"
-Core
