0 Members and 40 Guests are viewing this topic.
forest
Quote from: xenomorphlabs on February 09, 2012, 12:42:06 PM
If that light blue box is an emergency UPS, then it could be that it requires mains power first and then senses the removal of that and switches to battery
HOWEVER the exact same light blue box has been used in the green box presentation WITHOUT mains power for startup which
lead me to believe that it is a 12 V DC inverter.
So Core's question is absolutely justified, why would it need a mains startup on the workbench, when in the outside green box
presentation it hadn't needed it ?
Only answer that i can think of is connected to the difference of starting the device up
in the 2 presentations.
In the green box presentation,the first switch was used, then he waited like 5 seconds and then flipped the 2nd switch.
On the workbench there is only 1 switch.
So it could be that a capacitor was charged with the first switch in the green box to provide a huge startup current to get the device running.
After all it was also looping back on itself.
YES!!!! Brilliant ! This inverter cannot stand the requirement to charge capacitor to high voltage because when loaded  it drops in voltage so it seems that older device was not well balanced or has mising fast charging circuit.Inverter overload and need a socket grid help !
This is my opinion ,so simple device , oh :-)
gsmsslsb
Kator01
Quote from: energia9 on February 09, 2012, 12:16:17 PM
I have the simplest logical idea on Tesla /kapanadze device.  only if you are interrested and not ignoring it.
will this site acceppt word document file?
Hi energia9,
you can upload your document here:
http://www.overunity.com/downloads/
scroll down to the bottom with the header "Category Name", click on
"General documents and files" then go to the bottom and click on "Add a Download" on the bar below pages-numbering and here you have then all control-elements for your upload.
Very complicated, indeed.
Hope you are successful. I certainly will not neglect your docuement.
Kator01
cosmoLV
Quote from: core on February 09, 2012, 02:19:49 PM
ok, thanks. So the output of the old inverter has a true ( )220 volts and a true (-)220 volts (A-C) Kinda like using a 1:1 transformer with the secondary not grounded if I understand correctly.
But what is the purpose of 'plugging' the cord into the bench outlet then removing it?
Also, this 2004 device is 5kw, the green box device is 3Kw. The coil used looks identical, where did the additional 2Kw go? Is the output unlimited depending only on components used? In other words could he have connected an additional 1Kw load to the green box device? How is he calculating output?
-Core
Green Box was 5Kw (who say that it is 3Kw) as i remember Tariel says in Georgian language that it produce 5Kw it can produce 7Kw but he afraid that it will burn out the transistors...
the old light-blue inverter is soviet inverter/voltage stabiliser/carger, as i hear in this video he says that battery has not much power to start sparkgap, that way he need to plug in outlet. (i think he has some electronics problem) but this is not important, tariel made it as he can...
Keep your chakras opened :)
hartiberlin
Quote from: xenomorphlabs on February 09, 2012, 06:32:29 AM
Where can one get the highest quality original upload of the 2004 workbench video. Where did it originate?
Best details can only be grasped from the highest quality version as the original recording is already quite lo q.
Hi,
I uploaded this original video in 720x576 in FLV Format over here:
http://www.2shared.com/video/ELhqwFB1/coil.html
You can use the free Videolan.org VLC player to play it.
Regards, Stefan.
