cosmoLV
 Again, by fast hand :) â€" Frequency Divider (in attachment is PCB etch .pdf)
Keep your chakras opened :)
TEKTRON
Quote from: Kator01 on February 09, 2012, 01:13:42 PM
@Stephan: the isolation of these wires are just a very thin green varnish and can not handle any higher voltage so you will get shorts between the windings. I buyed some cheap copper-cable ( solid version, no filaments) diameter 1.2 ( equals 1.5 mm exp2), stripped the plastik-isolation off in one piece ( 1 meter is possible without damaging the isolation ) then I took some 1 mm dia bare iron-wire put it through the isolation. It works because iron-dia is 0,2 smaller than the copper-wire fitted within this isolation.
Kator01
KATOR, HERE IS SOLID 14 GAGE STEEL WIRE WITH PVC INSULATION
http://www.ebay.com/itm/HILLMAN-PLASTIC-COATED-STEEL-CLOTHESLINE-WIRE-50FT-NEW-/390186179115?pt=LH_DefaultDomain_0&hash=item5ad8e89a2b
tagor
m786
Hello all,
I think that operation of device is so simple.
In document : PARAMETRIC EXCITATION OF ELECTRIC OSCILLATIONS from L. Mandelstam and N. Papalexi ,and also from work of Eric dollard you can see that is possible to excite electric oscillator but changing own parameters. Most of the people are experimenting with mechanical devices as rotary capacitor and so on... But there is magnetic amplifier, which is simple parametric changing device. You can see that by changing a primary current you can change a secondary induction - XL. which act as variable resistor in this time. from People mentioned above you can see that if you change induction in right time of oscillation(1/4 of the proper system period), then you can excite oscillator as swing.This will amplify energy in system many times.Then if you see the magnetic amplifier schematic, you can understand that if you have ferrite core spitted in 2, 3 bifilliar coils and one secondary coil winded over both half's of ferrite core, then you get to same schematics as in the magnetic amplifier...
So kapanadze found possibility hot to make parametric excited oscillator without using of mechanical devices, which usually means a big losses. Since you drive bifilliar coil with impulses, then rate of change of L in time is so big then also delta L is so big. energy in system is 0.5*delta L*I*I.
It is just my theory, i am working on practical test.
Instead of ferrite, you can use iron or other cores. Or we can use air core, but need to calculate current needs to change induction as much as possible and as fast as possible.
energia9
Quote from: Kator01 on February 09, 2012, 06:42:05 PM
Hi energia9,
you can upload your document here:
http://www.overunity.com/downloads/
scroll down to the bottom with the header "Category Name", click on
"General documents and files" then go to the bottom and click on "Add a Download" on the bar below pages-numbering and here you have then all control-elements for your upload.
Very complicated, indeed.
Hope you are successful. I certainly will not neglect your docuement.
Kator01
Thank you Kator.
download pdf.
read carefully to get the feeling.
