hartiberlin
Quote from: nightwind on February 13, 2012, 10:59:09 PM
Extra Device
Did anyone notice the purple wire exiting the coil and going downward (hard to see) and then looping under the bench to some other device resting on a stool? One of the guys twist a wire to the purple wire at 7:31.  The device is visible at 1:42, 7:45, & 13:14 in the video.  I uploaded a poor screen capture of it at 13:14.  Can anyone identify that device?
At 11:45 you can see the black box under the table very nicely.
There are only 4 cables going into it.
the 2 AC 220 Volts cables going into it as the input and
the 2 DC 12 Volts cables coming out of it again.
This is just a big AC to DC power supply converter.
cosmoLV
Quote from: Qwert on February 13, 2012, 11:26:26 PM
I don't. If this is true, then the idea of this whole forum is wrong. And allegations given in that post won't be removed within present generation.
No, no, no... you might be little missunderstand the meaning of message! This kind of forums are needed - there we can share and teach from each-other.
How many peoples are in these forums compare to whole world? Actually little bit!
We are those who want to do Bright and good things, not only us but similar forums too and not only forums, but out there without us are bad ones - the story is about them! (but maybe some of them are in these forums, who knows...!) And how we can divide bad and good ones? Intimate question actually.
Whole situation is little bit complex.
I just recall to be realistic. (nothing bad or good, just message)
Keep your chakras opened :)
T-1000
Quote from: scratchrobot on February 13, 2012, 06:49:08 PM
Sounds like good experiment I want to try  :)
I already had good tests with open circuit, maybe you can explain more the second condition?
Where to put the two wires from resonator?
Thanks
You can start replacing TT secondary with it and those two windings are wound in opposite directions to each other.
xenomorphlabs
Quote from: hartiberlin on February 13, 2012, 09:14:43 PM
Hi  cosmoLV,
can you understand and translate the video ?
http://www.youtube.com/watch?v=B4X5zy0piSg
It really would help to know, what Tariel says there in this video.
Also
2. I wonder what device makes this huge buzzing sound, when Tariel
disconnects the 12 Volts battery and just starts the device just via the 220 Volts plug ??!
I guess it is the lightblue colored inverter.
This must be really a special inverter, as it has a 220 Volts input and
also a 12 Volts input and also a 220 Volts output.
It would be interesting to know, how the 220 Volts input to 220 Volts
output is working in this device and why it makes such a big transfoirmer buzzing noise.
3. Also interesting to know would be the function of the toggle switch on the
round box. What does it exactly trigger and did you notice that the light went on,
when it is toggled once back and forth, so it is not an on/off stwich but rather a toggle switch
that just generates a pulse somehow to switch on the lights and also switch off the lights...
Any idea, what this toggle switch could toggle ?
Maybe just switch off and on again the 220 Volts line to the coil ?
Regards, Stefan.
The conversations in this video are in georgian language.
An interesting question about the buzzing sound:
Why is it not at all audible anywhere in the green box demonstration? (Same light blue inverter used there)
It is very strong in the aquarium device demo too ! And it fades away after the device runs for some time (unusual)
As to the nature of that sound: Either magnetostriction of the transformer core
or a kinetic vibration of some sort not connected to magnetism directly (similar to Thrapps device sound)
The sound also ONLY occurs when the inverter is also connected to that little white mains box attached to the table leg.
Maybe some kind of ground feedback?
EDIT: If that white box is indeed at all connected to mains. Just looking at the cables it seems to be actually fed by the INVERTER's frontside
output cable. So by plugging the inverter backside cable into that box he would feed the inverter back on itself.
xenomorphlabs
Extra Device
Most likely it is this one (attached)
Not much to see. What can be seen is drilled ventilation holes in the lid indicating that there is heat being produced in the box ...
